Venkateswarlu N
Hi Seniors,
I have a situation.
Progress version: 10.2b.
OS: windows 2008 R2
Printer: XPS Writer/local Xerox Printer
I am trying to print a PDF, by setting 'session: printer' and using 'output to printer'.
Print happens, but it is all wrong. Whole document is printed in 2/3 lines.
and I can see an error 'Warning: Mixed printing mode detected. Use -wpp option for proper printing. (2858)'
I checked on this error but nothing helped.
Test code I am trying the print with
Am I doing something wrong? What do I need to do?
Note: I tried the os-command silent (copy document printer) and it works. This works over app-server correct?
Thanks,
Venky
I have a situation.
OS: windows 2008 R2
def var document as char no-undo init 'C:\testfile.pdf'.
def var printer as char no-undo init 'Microsoft XPS Document Writer'.
def var pfiledata as memptr no-undo.
def stream infile.
file-info:file-name = document.
set-size(pfiledata) = file-info:file-size.
input stream infile from value(file-info:full-pathname) binary no-map no-convert.
import stream infile unformatted pfiledata.
session: printer-name = printer.
output to printer.
export pfiledata.
input stream infile close.
set-size(pfiledata) = 0.
output close.
Thanks,
Venky
