Hi,
I'm opening up a simple .txt file in msWord with pagebreaks. Great. The problem is that Word annoyingly enough opens it in "normal"- view mode (don't know the exact names in english versions, using swedish version).
Due to that, the pagebreaks are only visible as dotted lines in the pages, and therefore the user keeps telling me that the pagebreaks are wrong... If you print the report it looks right, since the only problem is the view-mode.
Does anyone know how to make word open the document in "page layout"-mode?
As for now I'm opening the file with a simple shellexecute-command and I was hoping I didn't have to use anything else if it's possible.
Thanks !
/Pejgan
Thanks !
/Pejgan
