[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Garbage collection for the sake of static temp-tables (in long-running _progres)
jmls
dbeavon are you aware that the GC only works with object classes, not handles ? As you mentioned that sometimes you get errors, perhaps this is of significance ? knowledgebase.progress.com/.../Implicitly-created-temp-table-not-deleted-when-returning-with-an-error-from-called-procedure Also, when you mention "static temp-table" is the temp-table definition static ?
