We have some application running on OpenEdge 10.0B and Windows platform. Something in the application is failing and the connection is not release. After sometime the application will fail to accept any new client connection because the maximum number of client connection has been reach and we will need to restart the App server. I have try to increase the maximum number of client connection but it only reduce the frequency we need to restart the server.
When I query the App server status using asbman I can see that the Active client is increasing very fast, e.g we only have less then 40 user login but I can see that the number of active clients is showing more then 500. Is there any way we can find out which workstation or user is consuming all these connection? Or is there a better way to diagnose this?
Thanks a lot.
Thanks a lot.
