algver123
Hi all, I am Mark Algvere and I work for Algver Management Consulting in Stockholm. I am developing a new application from scratch using Open Edge with Rollbase as User Interface tool. In my application all the field validations concerning input screens are made on the Open Edge side in the *.CLS files. I have problems to display the error message in Rollbase and also remain in the input screen in Rollbase when an error from Open Edge is sent. I think it should work as follows: If you enter an “X” (or any character) in the integer field “order number” in a Rollbase input screen you get the error message “Error x is not a valid integer”. The cursor moves to the top field. If you enter “9” and OpenEdge executes in the corresponding CLS file If eOrder.OrderNumber = 9 then RETURN ERROR “9 is not OK as input in this case”. Rollbase should display “9 is not OK as input in this case” on the same place as in the “X” example and move the cursor to the top of the input screen. The application should stay in the input screen. In my application the error message can always be display after the last field. It is not needed to send information from Open Edge exactly which field the error message should be displayed under. Is there a work around in Rollbase 2.2 to display message from the RETURN ERROR “error text” function in Open Edge ? In which Rollbase version will this be fixed properly ? As long as it is not possible to send error messages from OpenEdge to Rollbase it will not be as I see it possible to make any larger applications with the main logic on OpenEdge side. Best Regards, Mark Algvere Algver Management Consulting Vildkattsvägen 12 S-13336 Saltsjöbaden, Sweden Tel: +46-707-740616
