E
egarcia
Hello sauqad, I just wanted to give you a quick suggestion. Please check the URIs for the service and for the catalog are valid. You can enter the URIs in the web browser to see if you can connect. Also, check that the name of the host is the same as you see it in the web browser. If the host name is in upper case, the web browser will change to lower case and the web browser would complain with an error that looks like a CORS issue but it is actually the upper case in the name. I hope this helps.
