Godfrey Sorita
Hi Laurent, You haven't done any mistake. It seems that all services(except the views) from all objects are automatically generated after creating a mobile application regardless of their relationship. I tested it using the example in Rollbase in Action. Also, these services can be removed by clicking the (-) icon beside the service or containing folder. Though, I advise you to leave it as is for future use. Regards, Godfrey
