C
cverbiest
Hi I'd like to use ARAT to build an ImportTable I use ant -f /usr2/rtb/current/automation/ant/build_rtb_import.xml -DRtbImportWspaceId=rel1600 -DRtbImportSourceWorkspaces=Test -DBuildJsonProps=/usr2/rtb/current/automation/cce.json -DRtbPassword=$RTBPASSWORD only 40 objects make it to the import table I expect more than 10000. Which parameters should I use to import everything ? I don't know if it matters but rel1600 is a newly created workspace. workspace sources are defined but no import has ever been build. ant output rtbImportProcessing: [echo] Building import table... [PCTRun] Input command line truncated at 1024 bytes. [PCTRun] Trying to connect to : -db rtb -S 99999 -ld rtb -H xxxxx [PCTRun] PROPATH : /usr2/rtb/rtbbuild,/usr2/rtb/rtb115,/usr2/rtb/rtb115/rtb/proxy/p,/usr2/rtb/current/automation,/usr2/rtb/current/automation/scm/custom,/tmp/pct5716.pl,.,obnl,./char,./char/sources,./char/tools,./char/is,./src,./tty/,/usr/dlc/tty,/usr/dlc/tty/adecomm.pl,/usr/dlc/tty/OpenEdge.BusinessLogic.pl,/usr/dlc/tty/adeedit.pl,/usr/dlc/tty/OpenEdge.Core.pl,/usr/dlc/tty/adecomp.pl,/usr/dlc/tty/dataadmin.pl,/usr/dlc/tty/prodict.pl,/usr/dlc/tty/adeshar.pl,/usr/dlc/tty/OpenEdge.ServerAdmin.pl,/usr/dlc,/usr/dlc/bin [PCTRun] RUN appSolutions/appSolute/RTB/Automation/adrtb_buildimport.p (OUTPUT outParam0,OUTPUT outParam1) [PCTRun] Session parameters: {"ttProperties": [{ "BuildDebug": "true", "RtbInstallPath": "/usr2/rtb/rtb115", "RtbUser": "sysop", "RtbPassword": "********", "RtbImportWspaceId": "rel1600", "RtbImportSourceWorkspaces": "Test", "RtbImportMaxWorkspaces": "8", "RtbImportPmods": "*", "RtbImportTaskList": "", "RtbImportReleaseNum": "", "RtbImportHigherVerOnly": "true", "RtbImportCurrReleaseOnly": "true", "RtbImportIncludeAll": "true", "RtbImportCompleteTasksOnly": "true", "RtbImportDeleteExistingImportTable": "true", "RtbImportReportAfterBuild": "true", "RtbAppServerConnection": "AppServer://localhost:5163/asrtb_115", "RtbReportBaseDir": "/usr2/rtb/rtbbuild/logs", "RtbUseAppServer": "false"}]} [PCTRun] Starting Roundtable API for user : sysop... [PCTRun] PROPATH: /usr2/rtb/rtb115,/usr2/rtb/rtb115/rtb/proxy/p,/usr2/rtb/rtbbuild,/usr2/rtb/current/automation,/usr2/rtb/current/automation/scm/custom,/tmp/pct5716.pl,.,obnl,./char,./char/sources,./char/tools,./char/is,./src,./tty/,/usr/dlc/tty,/usr/dlc/tty/adecomm.pl,/usr/dlc/tty/OpenEdge.BusinessLogic.pl,/usr/dlc/tty/adeedit.pl,/usr/dlc/tty/OpenEdge.Core.pl,/usr/dlc/tty/adecomp.pl,/usr/dlc/tty/dataadmin.pl,/usr/dlc/tty/prodict.pl,/usr/dlc/tty/adeshar.pl,/usr/dlc/tty/OpenEdge.ServerAdmin.pl,/usr/dlc,/usr/dlc/bin [PCTRun] Logging into Roundtable API... [PCTRun] ** [Debug] : Creating client-side temp-dir [PCTRun] Session ID : 9102 [PCTRun] Setting paths in RTB API... [PCTRun] Mode: Client only (9102)... [PCTRun] Number of workspaces specified: 1, Maximum allowed workspaces: 8 [PCTRun] [PCTRun] Processing workspace: rel1600... [PCTRun] /*****************************************/ [PCTRun] Setting workspace in RTB session to 'rel1600'... [PCTRun] Building workspace import list for workspace : rel1600 [PCTRun] Import settings [PCTRun] ================= [PCTRun] Workspace : rel1600 [PCTRun] Source workspaces : Test [PCTRun] Product modules : [PCTRun] Tasks : [PCTRun] Releases : 0 [PCTRun] Higher versions only: yes [PCTRun] Current release only: yes [PCTRun] Complete tasks only : yes [PCTRun] ** [Debug] No import table exists [PCTRun] Building workspace import table ... [PCTRun] Building workspace import table completed [PCTRun] ** [Debug] Debug listing of objects in import table: [PCTRun] Object : ImageCollection.cls (INC) ... trimmed [PCTRun] Object : wget.sh (INC) [PCTRun] ** [Debug] Import table exists (40) [PCTRun] Import control table created. Number of records in import table: 40 [PCTRun] Setting 'include all' on import table... [PCTRun] ** [Debug] Debug listing of objects in import table: [PCTRun] Object : ImageCollection.cls (INC) ... trimmed [PCTRun] Object : wget.sh (INC) [PCTRun] ** [Debug] Import table exists (40) [PCTRun] Creating import analysis report... [PCTRun] Import analysis report created and written to file : /usr2/rtb/rtbbuild/logs/Imports/rel1600/rel1600_ImportReport_20151217_132552.txt... [PCTRun] Logging out of RTB API... [PCTRun] Return value : 0 [PCTRun] OUTPUT PARAMETER : /usr2/rtb/rtbbuild/logs/Imports/rel1600/rel1600_ImportReport_20151217_132552.txt [PCTRun] OUTPUT PARAMETER : yes
