[progress Communities] [progress Openedge Abl] Forum Post: Arat Workspace Apply Import Not...
C
cverbiest
Hi, I'm not sure if I configured something wrong or if ARAT is unaware of the server path. Roundtable TSMS release 11.5.1 appSolute RTB Automation Toolkit 11.5.01 Jenkins, RTB, ARAT are all running on the same linux server. workspace path is set correctly for the windows clients : /cce/rel16plus workspace server path is set correct for the linux server /usr2/cce/rel16lus I get error Cannot create directory: /cce/rel16plus in the logfile. it should be using /usr2/ cce/rel16plus log 11:56:34 [EnvInject] - Loading node environment variables. 11:56:34 Building on master in workspace /var/lib/jenkins/jobs/Roundtable 16plus Import/workspace 11:56:34 [ant] $ ant -file build_rtb_import.xml -DBuildJsonProps=/usr2/rtb/current/automation/cce.json -DRtbImportApplyImport=true -DRtbImportWspaceId=rel16plus 11:56:34 Buildfile: /usr2/rtb/rtb115_01/automation/ant/build_rtb_import.xml 11:56:35 11:56:35 start: 11:56:35 [echo] Looking for ${build.props} result ${BuildPropsAvailable} 11:56:35 [echo] Looking for /usr2/rtb/current/automation/cce.json result true 11:56:35 11:56:35 JsonProperties: 11:56:35 [echo] Loading /usr2/rtb/current/automation/cce.json properties file from JSON 11:56:35 11:56:35 readJSonProps: 11:56:35 [echo] Reading JSON properties file: /usr2/rtb/current/automation/cce.json 11:56:36 [echo] JSON properties loaded 11:56:36 11:56:36 setLogFilename: 11:56:36 11:56:36 startlogging: 11:56:36 [echo] BuildLogDir=/usr2/rtb/rtbbuild/buildlogs 11:56:36 [echo] Log (info) being written to: /usr2/rtb/rtbbuild/buildlogs/build_rtbimport_development_20160128_115635.log 11:56:36 11:56:36 default: 11:56:36 11:56:36 RTBImportPrompts: 11:56:36 [echo] Checking RTB Import parameters 11:56:36 11:56:36 RTBUserPrompt: 11:56:36 11:56:36 checkRTBProps: 11:56:36 11:56:36 checkRTBImportProps: 11:56:36 [echo] Import properties complete: true 11:56:36 11:56:36 checkTaskList: 11:56:36 [echo] Task list: 11:56:36 11:56:36 rtbImportProcessing: 11:56:36 [echo] Building import table... 11:56:36 [PCTRun] Input command line truncated at 1024 bytes. 11:56:36 [PCTRun] Starting Roundtable API for user : sysop... 11:56:36 [PCTRun] Logging into Roundtable API... 11:56:36 [PCTRun] Session ID : 148 11:56:36 [PCTRun] Setting paths in RTB API... 11:56:36 [PCTRun] Mode: Client only (148)... 11:56:36 [PCTRun] Number of workspaces specified: 1, Maximum allowed workspaces: 8 11:56:36 [PCTRun] 11:56:36 [PCTRun] Processing workspace: rel16plus... 11:56:36 [PCTRun] /*****************************************/ 11:56:36 [PCTRun] Setting workspace in RTB session to 'rel16plus'... 11:56:36 [PCTRun] Building workspace import list for workspace : rel16plus 11:56:36 [PCTRun] Import settings 11:56:36 [PCTRun] ================= 11:56:36 [PCTRun] Workspace : rel16plus 11:56:36 [PCTRun] Source workspaces : 11:56:36 [PCTRun] Product modules : 11:56:36 [PCTRun] Tasks : 11:56:36 [PCTRun] Releases : 0 11:56:36 [PCTRun] Higher versions only: yes 11:56:36 [PCTRun] Current release only: no 11:56:36 [PCTRun] Complete tasks only : no 11:56:37 [PCTRun] Building workspace import table ... 11:57:12 [PCTRun] Import control table created. Number of records in import table: 47 11:57:12 [PCTRun] Setting 'include all' on import table... 11:57:12 [PCTRun] ** Brtb_task record not on file. (138) 11:57:12 [PCTRun] Import analysis report created and written to file : /usr2/rtb/rtbbuild/logs/Imports/rel16plus/rel16plus_ImportReport_20160128_115712.txt... 11:57:12 [PCTRun] Logging out of RTB API... 11:57:12 11:57:12 readImportReport: 11:57:12 [mail] Sending email: rel16plus - Import results 11:57:12 [mail] Sent email with 1 attachment 11:57:12 [echo] Applying import table(s)... 11:57:13 [PCTRun] Starting Roundtable API for user : sysop... 11:57:13 [PCTRun] Logging into Roundtable API... 11:57:13 [PCTRun] Session ID : 149 11:57:13 [PCTRun] Setting paths in RTB API... 11:57:13 [PCTRun] Mode: Client only (149)... 11:57:13 [PCTRun] Setting workspace in RTB session to 'rel16plus'... 11:57:13 [PCTRun] 11:57:13 [PCTRun] Processing workspace: rel16plus... 11:57:13 [PCTRun] /*****************************************/ 11:57:13 [PCTRun] Checking import table for workspace: rel16plus... 11:57:13 [PCTRun] Applying workspace import table to workspace : rel16plus 11:57:19 [PCTRun] *** 11:57:19 [PCTRun] RTB import table processing error: 11:57:19 [PCTRun] 11:57:13 Initialize Import Failures for rel16plus log... 11:57:19 [PCTRun] 11:57:19 [PCTRun] Cannot import PCODE Object 'SessionInfo.cls'. 11:57:19 [PCTRun] Cannot assign PCODE Object 'SessionInfo.cls' version 010015 from Product Module 'cce.ccetools.sess' to Workspace 'rel16plus'. 11:57:19 [PCTRun] 11:57:19 [PCTRun] Cannot create directory: /cce/rel16plus log truncated
