[progress Communities] [progress Openedge Abl] Forum Post: Rtb Selective Compile (with...
C
cverbiest
I'm not sure if its because of ARAT or not. I see similar numbers of db accesses with our current compile using the rtb_api but it's not that slow. At first I though the ant/build_rtb_compile.xml job just hung, no feedback after more than an hour while the last rtb_api selective compile only took 10 minutes. I started adding a verbose option to automation/scm/custom/rtb/p/rtbcust_compiler.p, (currently hardcoded verbose no means of passing the parameter yet.) This shows me that it takes ages to compiling some sources. While waiting I see millions (literally) of accesses on the rtb_pname table, . [PCTRun] Processing workspace: rel16plus... [PCTRun] /*****************************************/ [PCTRun] Setting workspace in RTB session to 'rel16plus'... [PCTRun] Compile settings [PCTRun] ================= [PCTRun] Workspace : rel16plus [PCTRun] Task number : 000000000 [PCTRun] Module : * [PCTRun] Group : * [PCTRun] Object type : * [PCTRun] Object(s) : * [PCTRun] Force compile : no [PCTRun] Listings : no [PCTRun] Xref : yes [PCTRun] Ignore warnings : yes [PCTRun] Stop on error : no [PCTRun] Verbose : no [PCTRun] Starting custom selective compiler: [PCTRun] w:\rtb\current_win\automation\scm\custom\rtb\p\rtbcust_compiler.p [PCTRun] Performing selective compile for workspace: rel16plus [PCTRun] 2016-02-02T16:54:28 [PCTRun] Object: CselQuery.cls - OK [PCTRun] Pmod: be.cce.erpalg.CceSelect [PCTRun] Path: /cce/rel16plus/src/be/cce/erpalg/CceSelect/CselQuery.cls [PCTRun] [PCTRun] 2016-02-02T16:56:21 [PCTRun] Object: _pwrun.p - OK [PCTRun] Pmod: adecommx [PCTRun] Path: /cce/rel16plus/src/adecommx/_pwrun.p [PCTRun] [PCTRun] 2016-02-02T16:56:21 [PCTRun] Object: _pwsrch.p - OK [PCTRun] Pmod: adecommx [PCTRun] Path: /cce/rel16plus/src/adecommx/_pwsrch.p [PCTRun] [PCTRun] 2016-02-02T17:01:25 [PCTRun] Object: csel-d.p - OK [PCTRun] Pmod: ccealg [PCTRun] Path: /cce/rel16plus/src/ccealg/csel-d.p [PCTRun] [PCTRun] 2016-02-02T17:01:25 [PCTRun] Object: csel-w.p - OK [PCTRun] Pmod: ccealg [PCTRun] Path: /cce/rel16plus/src/ccealg/csel-w.p [PCTRun] [PCTRun] 2016-02-02T17:01:31 [PCTRun] Object: cselhfd-p.p - OK [PCTRun] Pmod: ccealg [PCTRun] Path: /cce/rel16plus/src/ccealg/cselhfd-p.p [PCTRun] [PCTRun] 2016-02-02T17:01:31 [PCTRun] Object: cslh-d.p - OK [PCTRun] Pmod: ccealg [PCTRun] Path: /cce/rel16plus/src/ccealg/cslh-d.p [PCTRun] [PCTRun] 2016-02-02T17:01:31 [PCTRun] Object: cslh-w.p - OK [PCTRun] Pmod: ccealg [PCTRun] Path: /cce/rel16plus/src/ccealg/cslh-w.p [PCTRun] [PCTRun] 2016-02-02T17:06:48 [PCTRun] Object: loktyp-p.p - OK [PCTRun] Pmod: erpsto [PCTRun] Path: /cce/rel16plus/src/erpsto/loktyp-p.p [PCTRun] I monitored the data accesses (vst table data) starting at 17:01:31 at 17:05 I gave up waiting and collected the data lqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk xFile-Name Connection Read Create Update Delete Deltax xqqqqqqqqqqq qqqqqqqqqqq qqqqqqqqq qqqqqqqqq qqqqqqqqq qqqqqqqqq qqqqqqqqqx xrtb_pname 244 1.961.595 0 0 0 1.961.595x xrtb_object 244 2.816 0 0 0 2.816x xrtb_path 244 493 0 0 0 493x xrtb_wspace 244 457 0 0 0 457x xrtb_session 244 45 0 0 0 45x xrtb_dbfile 244 39 0 0 0 39x xrtb_brepo 244 0 0 0 0 0x xrtb_commits 244 0 0 0 0 0x xrtb_count 244 0 0 0 0 0x Not using appserver : I tried switching to using an rtb appserver connection but if I blank out the rtb database connection parameters the job no longer starts. If I don't blank it out it still makes a connection to the rtb database even though I specify to use an Appserver .
