[stackoverflow] [progress Openedge Abl] How To Deploy Trireme Project On Apigee Using...
ANIL VISHVKARMA
I have design a data layer API to establish openedge database connection using trireme-jdbc. The code is working solid when I am running the file by trireme command using cygwin, but when I start the complete project through apigeetool using command 'a127 project start' then it throws some error regarding trireme. I have used generic-pool package for database connection pooling along with trireme-jdbc.Below is the file that is running my trireme but not by a127. This is a apigee API so folder structure is totally as per apigee standard and swagger is also used here.
var a127 = require('a127-magic');
var express = require('express');
var Pool = require('generic-pool').Pool;
var jdbc = require('trireme-jdbc');
var app = express();
module.exports = app; // for testing
// initialize a127 framework
a127.init(function(config) {
// include a127 middleware
app.use(a127.middleware(config));
var pool = new Pool(
name : 'Suppllier Collaboration - @Anil',
create : function(callback) {
var connOpenedge = new jdbc.Database(
url : 'jdbc:datadirect:eek:penedge://serverhost:portno;DatabaseName=xxxxx',
properties : {
user : 'db_user',
password : 'db_password',
callback(null, connOpenedge);
destroy : function(client) {
client.end();
max : 10,
min : 2,
idleTimeoutMillis : 30,
log : true
// error handler to emit errors as a json string
app.use(function(err, req, res, next) {
console.log('we are just enter in app.js file');
if (typeof err !== 'object') {
// If the object is not an Error, create a representation that appears to be
err = {
message: String(err) // Coerce to string
} else {
// Ensure that err.message is enumerable (It is not by default)
Object.defineProperty(err, 'message', { enumerable: true });
// Return a JSON representation of #/definitions/ErrorResponse
res.set('Content-Type', 'application/json');
res.end(JSON.stringify(err));
pool.acquire(function(err, conn) {
if (err) {
throw err;
} else {
app.get("/getData", function(req, res) {
conn.execute('select * from "po" where "po-num" = ? and "vend-num" = ? ',
[4322452, 4301170 ], function(err, result, rows) {
if (err)
res.json("Sorry !Error to get data from symix....");
else
res.json(rows);
var ip = process.env.IP || 'localhost';
var port = process.env.PORT || 10010;
// begin listening for client requests
app.listen(port, ip);
console.log('we are inside app.js file');
console.log('try this:\ncurl http://' + ip + ':' + port + '/hello?name=Scott');
