Arden Hecate
Progress® OpenEdge® 13.1 continues the innovation introduced with the OpenEdge 13 series, delivering focused enhancements that help organizations keep mission-critical applications current without disrupting the systems their businesses depend on.
From more expressive ABL development to AI-assisted diagnostics and improvements across application server resilience, security administration and database operations, OpenEdge 13.1 helps development and operations teams modernize at a manageable pace while preserving the value of existing applications.
Modernization does not always require sweeping change. For organizations that rely on OpenEdge applications every day, it also means making development easier, improving how teams troubleshoot issues, strengthening operational resilience and simplifying ongoing administration.
OpenEdge 13.1 focuses on these practical improvements, helping developers, administrators and DBAs improve the way they build, manage and maintain OpenEdge applications.
OpenEdge 13.1 builds on the foundation of the 13 series with practical enhancements designed to make a difference in the day-to-day work of development and operations teams.
Whether you are modernizing ABL development, investigating memory issues, managing application server resources or maintaining your OpenEdge database environment, OpenEdge 13.1 provides new capabilities to help you move forward while protecting the value of the applications your business depends on.
Ready to learn more? Read the What’s New in Progress OpenEdge 13.1 whitepaper for a deeper look at the enhancements in this release.
Why OpenEdge 13.1 Matters
The Value of OpenEdge 13.1
- Strongly Typed Annotations for OOABL Reflection: Enable ABL developers to express metadata, code behavior and architectural intent using strongly typed annotations, supporting more structured, reusable approaches to application development.
- AI-Assisted OpenEdge Memory Profiler Analysis: Helps developers and support teams interpret OpenEdge Memory Profiler recordings with summaries of memory consumers, unusual patterns and suggested next investigative steps.
- Compiler Optimization for Assignment Statements: Enables assignment statements to perform on par with ASSIGN statements, helping improve application execution efficiency without requiring source-code changes.
- PAS for OpenEdge Agent Session Life-Cycle Management: Provides configuration settings for trimming ABL sessions, helping administrators manage long-running or high-memory sessions and improve application server stability.
- OS-Provided Certificate Store Support: Allows OpenEdge products to use operating system certificate stores, simplifying certificate updates and reducing maintenance across individual installations.
- Improved Latch Performance:Optimizes database latch behavior to reduce contention around shared resources and support responsiveness under demanding workloads, including multi-core and Non-Uniform Memory Access (NUMA) environments.
- Enhanced Index Maintenance: Extends IDXMOVE to inactive indexes and helps DBAs identify candidates for IDXCOMPACT UNUSEDBLOCKS, supporting more efficient database administration and storage management.
- .NET 10 Support: Supports continued platform compatibility and ecosystem readiness.
What Does This Mean for You?
