[Progress News] [Progress OpenEdge ABL] Part 1: What Is Low-Code Workflow Automation? A Practical Guide for Modern Businesses
N
Neeshma Mehta
Every business runs on workflows. Whether it’s approving a purchase request, onboarding a new employee or routing a customer support ticket, work moves through a series of steps involving people, systems and decisions.
The challenge is that many organizations still rely on email chains, spreadsheets and manual handoffs to keep these processes running. As businesses grow, these approaches often create bottlenecks, increase the risk of errors and make it difficult to understand where work stands at any given time.
Low-code workflow automation offers a more efficient approach. Using visual development tools and prebuilt integrations, organizations can automate routine tasks and connect systems without building every process from scratch. This allows teams to streamline operations while maintaining the flexibility to support unique business requirements.
Workflow vs. Process: What’s the Difference?​
The terms workflow and process are often used interchangeably, but they describe different things.
A business process is the broader objective an organization wants to achieve, such as employee onboarding or customer order fulfillment. A workflow is the series of tasks, approvals and decisions that help complete part of that process.
For example, employee onboarding is a business process. The specific workflow might include collecting paperwork, creating system accounts, routing approvals and notifying IT. Low-code workflow automation focuses on orchestrating these individual steps so work moves automatically from one stage to the next.
How Low-Code Workflow Automation Works​
At its core, a workflow begins with a trigger. This could be a submitted form, a database update, a customer request or an API call from another application. Once triggered, the workflow evaluates business rules, performs actions, routes approvals and updates systems based on predefined logic.
Consider a purchase request. When an employee submits a request, the workflow might automatically approve purchases below a certain dollar amount while routing larger requests to a manager or finance team. Once approved, it can create a purchase order, update financial systems, send notifications and maintain an audit trail of every action taken.
If something unexpected happens, such as missing information or an overdue approval, the workflow can trigger exception-handling steps such as reminders, escalations or alternate approval paths. Rather than requiring employees to manually track and manage every step, the platform manages the process automatically.
Why Organizations Are Adopting Low-Code Platforms​
Workflow automation is not a new concept, but low-code platforms make it much more accessible. Traditional development often requires significant coding effort and long implementation cycles, while no-code platforms can become limiting when organizations need more advanced functionality.
Low-code strikes a balance between speed and flexibility. Business teams can use visual tools to design workflows, while IT teams can extend functionality through APIs, custom integrations and business rules when needed.
This approach helps organizations reduce manual work, improve process consistency and gain greater visibility into operations. It also allows teams to adapt workflows more quickly as business requirements change, without requiring extensive redevelopment.
Choosing the Right Workflow Automation Platform​
Not all workflow automation platforms are created equal. While ease of use is important, organizations should also consider how well a platform will support future growth and evolving business needs.
Strong workflow platforms typically provide visual design tools, integration capabilities, approval management, security controls, monitoring and auditability. The ability to connect with existing applications and data sources is particularly important because most workflows span multiple systems rather than operating in isolation.
Organizations should also evaluate governance, scalability and support for more advanced automation initiatives. As workflow programs mature, many businesses look to incorporate AI-driven decision-making, intelligent routing and process orchestration capabilities.
Implementing Low-Code Workflow Automation Successfully​
Successful automation initiatives usually start with a clear understanding of the process being improved. Teams should identify repetitive, rule-based workflows that create measurable business impact, then map existing steps, stakeholders and approvals before building automation.
Testing is equally important. Organizations should validate workflow logic, integration points and exception scenarios before deployment. Establishing role-based permissions, securing credentials and monitoring workflow performance are also critical operational practices.
Once workflows are in production, ongoing monitoring helps teams identify bottlenecks, track performance and continuously improve process efficiency. Having documented recovery procedures and clear ownership ensures issues can be resolved quickly when they occur.
Looking Ahead​
Low-code workflow automation helps organizations connect people, systems and data through streamlined, automated processes. By combining visual development, business rules and enterprise integrations, it enables teams to work more efficiently while improving visibility and governance.
In Part 2, we’ll explore real-world workflow automation examples across different business functions. In Part 3, we’ll examine how AI orchestration builds on workflow automation to enable more intelligent, adaptive business operations.
Ready to streamline your business processes? Discover how Progress Corticon helps automate decisions and simplify complex workflows.
