MBeynon
Hi, As above I have a windows shortcut with the following; Target; C:\OE102B\bin\prowin32.exe -b -basekey ini -ininame RunTasks.ini -pf RunTasks.pf -p RunTasks.r -param '1,2,3' Start In; C:\.....jobs. My problem is that the PROPATH does not seem to getting set. My RunTasks.p file tries to access a static property of a class; ...utilities.LoadConfigConfig = ipcConfigPath NO-ERROR. But I get the error; LoadConfig error: Static instance failed to load. Cannot reference ....utilities.LoadConfig. (14631) I tried to instanciate an instance class too but with no luck. The error was; ** "...taskscheduler.TaskScheduler" was not found. (293) My ini file looks correct. I also tried not using an ini file and using a starter program to set the correct PROPATH and call my RunTasks.p, also with no luck. Can anyone help with this? Thanks, Mark.
