K
Keerthy Yeddula
Hi, You cannot publish exported ABL Web Application (war) to rest manager. You can export ABL Web Application as incremental zip and publish paar files to rest manager. Following are the steps to publish paar files to rest manager. 1. Export ABL Web Application as zip (select 'Export services for incremental deployment' radio button) 2. Extract zip and from proenv publish paar to rest manager using the following command: restman -i restmgr1 -appname -file -republish 3. Add newly deoplyed paar entry under archiveFiles section in web.xml file web.xml location: DLC\servers\tomcat\pdsoe\ \WEB-INF\web.xml entry: archiveFiles 4. Restart rest manager. Your service will be up and running. Hope this helps. Thanks, Keerthy.
