P
Peter Judge
You can leave it out, but you will have to change/add a new handle property as appropriate. handler42=OpenEdge.Web.DataObject.DataObjectHandler:/ If you want your own prefix, add it handler43=OpenEdge.Web.DataObject.DataObjectHandler:/dp/ If you do that, you'll have to add some code in your session startup to tell the DOH that it should expect that prefix assign OpenEdge.Web.DataObject.DataObjectHandler:HANDLER_PREFIX= 'dp' . You don't need that code if you want an empty prefix (the DOH will try 'pdo' and nothing by default).
