hi all, ive a problem with a progress table; im passing a very simple query "select * from pub.oedites" and it works fine; the CommandBuilder used to generate the insert command doesnt works as only the key field is considered. Is there a know issue for wich the other selected fields are not considered? I also used to list every single field of the over 140 available for this table but with the very same result.
thanks,
thanks,
