Index Problems
Joel J.J. Heber
I built an Index, basic one with the index editor ,
NON-UNIQUE,
not worded,
3 fields asc,
active,
standard index
and after it's creation I try to run a standard module. I get........
CRC for IM-TRANS-PROD does not match CRC in so/batchpa.p Try recompiling (1896)
Unable to locate index gl-control.
Same for all other functions.......I get unable to locate [indexname]
I delete my index and voila everything is normal again......
Can someone relate!!!!!!!!
Help I need this index for a program I wrote or else it's a snail.
Joel
:dead: :confused: :mad:
Joel J.J. Heber
MY 2 cents......reflections
I think it is a problem within the shared memory segment.....where the lk file is compared and it isn't the same so it jamms......
Which is probably why it worked fine when I run indexes on the backup server.
hmmmmmmmmm,..........
dkellgren
Are there any database triggers?
We had a similar issue and had to DELETE our db triggers, commit the changes, then re-add the db triggers. Without doing that, we kept getting CRC errors that we couldn't resolve.
-Dan
Aim
Joel J.J. Heber
ya there is
tons of them....but i cant read them .....would have to de-compile or reverse-engineer the code.......it's a 3rdparty thing.....we run off a platform.
Joel
Crittar
Silly question but...
Have you tried re-compiling? I had a similar problem once and a recompile of the program accessing the table cured it.
