Forum Post: RE: RED FLAG: Import/Installation from Rollbase XML
Ryan Canja
Hi Santosh, May I follow the findings from your team about the file I gave you? Case # is 00279453 for your reference. We tried to upload the same file using the 2.2.0.0 version, but still the same problem we encountered. Below are the details of the issues: 1. Missing views with filters (with own object) - checked object and their relationship in the imported xml and found it; object was also found in UI 2. Filters are detached upon xml import. 3. Some records cannot be saved even if all fields are filled-up - checked all hidden fields and found no required fields. "Error: Invalid data. Review error message below to correct your data." 4. Found some validations in the app that are not working, but functions in the original version 5. Found some triggers in the app that are not working, but functions in the original version Thanks!
