MarkHeppenstall
Hi guys, I wonder if someone has any ideas on this. I have an application that runs on an Appserver and everything worked OK until I renamed the _proapsv.exe (and _proapsv.exe.config) to something else - there are lots of Appserver serving different environments / processes so calling them different names aids identification of processes. I tracked the problem down to a class that reads from the registry using the .Net assemblies. The offending code which I isolated to a stand alone TestAppserver.p is:- DEFINE VARIABLE lv-BaseRegistryKey AS CLASS Microsoft.Win32.RegistryKey. ASSIGN lv-BaseRegistryKey = Microsoft.Win32.Registry:LocalMachine. This generates the following protrace file:- ===================================================== PROGRESS stack trace as of Thu Dec 11 14:30:04 2014 ===================================================== Progress OpenEdge Release 11.2 build 1196 on WINNT Startup parameters: -pf C:\Progress\OpenEdge\startup.pf,-cpinternal ISO8859-1,-cpstream ISO8859-1,-cpcoll Basic,-cpcase Basic,-d dmy,-numsep 44,-numdec 46,(end .pf),-logginglevel 2,-logfile C:\OpenEdge\WRK\Test.server.log,-ubpid 9660,-Ms 1,-logname Test,-logentrytypes ASPlumbing,DB.Connects,-logthreshold 0,-numlogfiles 3,-ASID 1,-ubpropfile C:\Progress\OpenEdge\properties\ubroker.properties,-ipver IPv4,-Mm 4096,-h 10 Exception code: E0434352 Fault address: 76902F71 01:00011F71 C:\Windows\SYSTEM32\KERNELBASE.dll Registers: EAX:010CE108 EBX:00000005 ECX:00000005 EDX:00000000 ESI:010CE1CC EDI:00000001 CS:EIP:0023:76902F71 SS:ESP:002B:010CE108 EBP:010CE160 DS:002B ES:002B FS:0053 GS:002B Flags:00200212 Debugging dll: C:\Progress\OpenEdge\bin\DBGHELP.DLL Symbol Path: C:\Progress\OpenEdge\bin;C:\Progress\OpenEdge\pdbfiles Call Stack: Address Frame 76902F71 010CE160 RaiseException+48 729A5DDF 010CE200 GetPrivateContextsPerfCounters+26C5D 72ABFF3F 010CE230 CreateHistoryReader+14648 72AC8694 010CE2C4 CreateHistoryReader+1CD9D 71601337 010CE2D4 0001:00000337 C:\Windows\Microsoft.NET\Framework\v4.0.30319\clrjit.dll 7160294C 010CE9FC 0001:0000194C C:\Windows\Microsoft.NET\Framework\v4.0.30319\clrjit.dll 71602F5C 010CEA7C 0001:00001F5C C:\Windows\Microsoft.NET\Framework\v4.0.30319\clrjit.dll 71603151 010CEA94 0001:00002151 C:\Windows\Microsoft.NET\Framework\v4.0.30319\clrjit.dll 71603208 010CEAB4 0001:00002208 C:\Windows\Microsoft.NET\Framework\v4.0.30319\clrjit.dll 7160B88A 010CEAF0 0001:0000A88A C:\Windows\Microsoft.NET\Framework\v4.0.30319\clrjit.dll 7160B9C7 010CEB68 0001:0000A9C7 C:\Windows\Microsoft.NET\Framework\v4.0.30319\clrjit.dll 7160B28D 010CEC58 0001:0000A28D C:\Windows\Microsoft.NET\Framework\v4.0.30319\clrjit.dll 7160BCAC 010CEC7C 0001:0000ACAC C:\Windows\Microsoft.NET\Framework\v4.0.30319\clrjit.dll 728314A7 010CECCC CoUninitializeEE+F04F 72831541 010CED0C CoUninitializeEE+F0E9 72831583 010CED70 CoUninitializeEE+F12B 728317DF 010CF110 CoUninitializeEE+F387 728301DB 010CF1EC CoUninitializeEE+DD83 728303F3 010CF260 CoUninitializeEE+DF9B 7281D0E6 010CF2C8 DllRegisterServerInternal+1DCA 72802B0C 010CF2F8 0001:00001B0C C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dll 03C658C2 010CF32C 0000:00000000 03C64FA3 010CF450 0000:00000000 016ECD2C 010CF464 Progress::ClrBridge::ITypeManager::ITypeManager+2FC 012B40E6 010CF488 dbut_utfIsLink+131916 ** ABL Stack Trace ** -- TestAppserver.p at line 3 (.\TestAppserver.r) ** Persistent procedures/Classes ** ** PROPATH ** .,C:\Progress\OpenEdge\tty,C:\Progress\OpenEdge\tty\adecomm.pl,C:\Progress\OpenEdge\tty\adecomp.pl,C:\Progress\OpenEdge\tty\adeedit.pl,C:\Progress\OpenEdge\tty\adeshar.pl,C:\Progress\OpenEdge\tty\dataadmin.pl,C:\Progress\OpenEdge\tty\prodict.pl,C:\OpenEdge\WRK,C:\Progress\OpenEdge,C:\Progress\OpenEdge\bin ** Databases (logical/type/physical) ** ** End of Protrace ** So you can see that the error is raised by the CLR and I cannot seem to CATCH it or find an explanation as to why. If I rename the Appserver process back to _proapsv.exe everything is fine - but change it to any other name and this is what happens. Anyone seen this before? or have any ideas why? and if so is there a resolution that doesn't involve renaming all my Appservers back to _proapsv.exe? Thanks, Mark
