[Stackoverflow] [Progress OpenEdge ABL] Problem loading .NET assembly by a CGI Module in IIS 8
L
Lieven Cardoen
I have a CGI Module running in IIS8. I fails when trying to load .NET Assemblies.
The executable is a Progress (OpenEdge) Application from the 20th Century.
Looking with Fusion++, I get this log:
*** Assembly Binder Log Entry (30/10/2020 @ 8:59:55) ***
The operation failed.
Bind result: hr = 0x80070002. The system cannot find the file specified.
Assembly manager loaded from: C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dll
Running under executable \\?\C:\MiaWeb\bin\nph-cybermia.exe
--- A detailed error log follows.
=== Pre-bind state information ===
LOG: DisplayName = Progress.NetUI, Version=11.7.0.1811, Culture=neutral, PublicKeyToken=null
(Fully-specified)
LOG: Appbase = file://?/C:/MiaWeb/bin/
LOG: Initial PrivatePath = NULL
LOG: Dynamic Base = NULL
LOG: Cache Base = NULL
LOG: AppName = nph-cybermia.exe
Calling assembly : (Unknown).
LOG: This bind starts in default load context.
LOG: No application configuration file found.
LOG: Using host configuration file:
LOG: Using machine configuration file from C:\Windows\Microsoft.NET\Framework\v4.0.30319\config\machine.config.
LOG: Policy not being applied to reference at this time (private, custom, partial, or location-based assembly bind).
LOG: Attempting download of new URL file://?/C:/MiaWeb/bin/Progress.NetUI.DLL.
LOG: Attempting download of new URL file://?/C:/MiaWeb/bin/Progress.NetUI/Progress.NetUI.DLL.
LOG: Attempting download of new URL file://?/C:/MiaWeb/bin/Progress.NetUI.EXE.
LOG: Attempting download of new URL file://?/C:/MiaWeb/bin/Progress.NetUI/Progress.NetUI.EXE.
LOG: All probing URLs attempted and failed.
The file Progress.NetUI.DLL can be foundin C:\MiaWeb\bin .
Is there a way to get more information about what is going wrong?
C:\OpenEdge\1175_32\DLC\bin>sn -T Progress.NetUI.dll
Microsoft (R) .NET Framework Strong Name Utility  Version 4.0.30319.0
Copyright (c) Microsoft Corporation.  All rights reserved.
Progress.NetUI.dll does not represent a strongly named assembly
The URL file://?/C:/ seems odd. Other than that, maybe it has to do with IIS8 and CGI Module blocking .NET Assemblies? Maybe it should be strongly named?
