Running Progress from Oracle Virtual PC, recreate Database?
PanicProgress
Hello everybody:
I'm trying to setup Progress 9.1b in Windows 7 through Oracle Virtual PC - Windows XP,
and, I have this situation:
There is several databases which original paths are: D:\DATABASE\DATABASE FOLDER...
Inside virtual PC - Windows XP I only have a C:\ disk , I have a shared folder set to a network drive named D:\
so I have D:\DATABASE\ DATABASE FOLDER...
but .. :(
I get the "JunMsg023 error 20931"
and something like "file not found" ,
when I try to start databases through Progress Explorer Tool.
It's like , Progress doesn't recognize the D:\ drive.
Someone told me that I have to re-create the databases again through Progress.. but I don't know how to do it, if someone could help me, ... :) thanks in advance.
Does somebody have tried to do similar stuff? running Progress inside a Virtual Machine ?
regards!
Rob Fitzpatrick
I think we need clarification on a few things.
It sounds like you're actually trying to set up Progress 9.1b in a Windows XP VM, not in Windows 7. I assume Windows 7 is the host OS. Is this correct?
Is your virtualization software Microsoft Virtual PC or Oracle VirtualBox?
Original paths on which machine?
Your databases reside on some physical machine, let's call it dbserver. When you are logged in to dbserver, the databases are in a directory structure like D:\database\db1, D:\database\db2, etc. You have shared the directory D:\database, so the DB directories's UNC paths are \\dbserver\database\db1, \\dbserver\database\db2, etc. I assume dbserver is also running Windows XP and has Progress 9.1b installed, with the same Progress service pack as your VM.
In your VM you have created a mapped drive called D:, and it points to UNC path \\dbserver\database. So in your VM the databases reside in D:\db1, D:\db2, etc. Is this correct so far?
In Windows Explorer on the VM can you see a directory listing of the database directories on dbserver using the D: drive mapping?
Yes, you can run Progress databases in virtual machines. It's a common practice.
