PROREST from tape problem
Glenn Edwards
Hi,
I have 2 IBM RS6000 F50 machines. Both with 4mm 12/24 (DDS3) dat drives.
I have run a prorest to tape on one machine and am trying to restore it to the other. Although everything seems the same the job fails with the following error.
NB - The versions of progress (8.3B) and AIX (4.2) are the same.
Error message
This is a full backup of /usr3/livecpydb/livecpymfg.db.
This backup was taken Wed Apr 21 14:11:55 2004.
It will require a minimum of 2792525 blocks to restore.
Verify pass started. (3751)
SYSTEM ERROR: Read of /dev/rmt0.1 failed, errno = 78 (1052)
Remove volume 1 from /dev/rmt0.1. (3761)
Please prepare volume 2 on /dev/rmt0.1, press enter when ready or type "quit".
Warning: This is not the next volume in sequence.
This is volume 1. The expected volume is 2
Do you want to continue? [y/n]: y
Started restoring volume 1. (3763)
quit
Read 39206 blocks in 00:19:56
Backup for /usr3/livecpydb/livecpymfg.db did not verify.
I have borrowed a DDS4 drive and the prorest passes the prorest -vp.
I would appreciate any help on this matter.
Many thanks
Glenn Edwards
You could try using the -vs parameter to specify the tape volume size, though I must confess I have never seen this behaviour in Progress.
