[progress Communities] [progress Openedge Abl] Forum Post: Re: Webspeed Pasoe - How Do I...
E
egarcia
Hello, In PDSOE, you can map multiple URIs to the same service/WebHandler by adding it to the Resource URI(s) list in the New Project wizard, the New Service wizard (when adding a new service to a project) and also from the Edit ABL Service dialog (from Defined Services). Because you are working with WebHandlers and have worked with Progress Data Objects, you might be interested in the following sample that that shows a generic/dynamic service to access data from the JSDO: community.progress.com/.../2677 I hope this helps.
