Rob Debbage
Hello, Per the support case that you raised for this, no versions of OpenEdge are currently certified for use on Microsoft Azure. Additionally, we cannot currently avoid the dependency on Microsoft Visual C++ 2010 Redistributables due to the use of Microsoft Visual Studio 2010 as our compiler. As discussed, support for Microsoft Visual C++ 2010 Redistributable on Microsoft Azure should be clarified with Microsoft, given the discrepancies in their online articles where www.microsoft.com/.../details.aspx does not list Windows 2012 / Windows 10 as a supported platforms but support.microsoft.com/.../2661358 states that they are supported. I would suggest that the second article is correct and supersedes the first article, with the first not having been updated since the release of the package in / around 2010/2011. Note that the first article completely omits platforms released after this date (Windows 8 / 8.1, Windows 2012 / 2012 R2, Windows 10). The second article was reviewed last year (08/10/2015) so I would suggest that it contains the correct details. Given that we do certify Windows 8 / 8.1, Windows 2012 / 2012 R2, Windows 10 for use with OpenEdge, I would suggest that the Microsoft Visual C++ 2010 Redistributables are supported on these platforms. Regards, Rob
