hi,
i´m a bloody newbie on progress so i need your help. i´m not sure if my post is right in this forum. so my problem is this: i got 6 databses. for every three databases is one appserver active. but one of the appservers, a copy of the first one but with different port, doesn´t start right up. after a reboot of the system it starts. in the progress explorer status dialog box are three serverthreads with the status STARTING. they never reach the status AVAILABLE. here is what´s in the broker log file:
main>======================================================================
main>(20.09.2004 10:14:03:437) d:\swisscare\sc2_as.broker.log opened.
main>(20.09.2004 10:14:03:484) ubroker version: v91D (14-Apr-03) (8038)
L-21030>(20.09.2004 10:14:03:546) Started listener thread: L-21030 (8043)
L-21030>Starting 5 server threads ... (8053)
S-0001>(20.09.2004 10:14:03:578) Started server thread: S-0001. (8101)
S-0002>(20.09.2004 10:14:03:687) Started server thread: S-0002. (8101)
S-0003>(20.09.2004 10:14:03:781) Started server thread: S-0003. (8101)
S-0004>(20.09.2004 10:14:03:890) Started server thread: S-0004. (8101)
S-0005>(20.09.2004 10:14:03:984) Started server thread: S-0005. (8101)
S-0001>Started server: "C:\Programme\PROGRESS\bin\_proapsv.exe" -ubpid 2180 -Ms 1 -logname sc2_as -logfile "d:\swisscare\sc2_as.server.log" -logginglevel 2 -logentrytypes 0 -ASID 1 -ubpropfile "C:\Programme\PROGRESS\properties\ubroker.properties" (8108)
S-0001>(20.09.2004 10:14:04:750) Message from server : Startup Procedure Failed (8113)
S-0001>(20.09.2004 10:14:04:812) IOException reading message from server : java.io.EOFException: pipe to server broken (8117)
S-0001>(20.09.2004 10:14:04:828) ERROR: cannot start server. (8100)
S-0002>Started server: "C:\Programme\PROGRESS\bin\_proapsv.exe" -ubpid 2180 -Ms 1 -logname sc2_as -logfile "d:\swisscare\sc2_as.server.log" -logginglevel 2 -logentrytypes 0 -ASID 2 -ubpropfile "C:\Programme\PROGRESS\properties\ubroker.properties" (8108)
S-0002>(20.09.2004 10:14:05:281) Message from server : Startup Procedure Failed (8113)
S-0002>(20.09.2004 10:14:05:296) IOException reading message from server : java.io.EOFException: pipe to server broken (8117)
S-0002>(20.09.2004 10:14:05:296) ERROR: cannot start server. (8100)
S-0003>Started server: "C:\Programme\PROGRESS\bin\_proapsv.exe" -ubpid 2180 -Ms 1 -logname sc2_as -logfile "d:\swisscare\sc2_as.server.log" -logginglevel 2 -logentrytypes 0 -ASID 3 -ubpropfile "C:\Programme\PROGRESS\properties\ubroker.properties" (8108)
S-0003>(20.09.2004 10:14:06:296) Message from server : Startup Procedure Failed (8113)
S-0003>(20.09.2004 10:14:06:296) IOException reading message from server : java.io.EOFException: pipe to server broken (8117)
S-0003>(20.09.2004 10:14:06:296) ERROR: cannot start server. (8100)
S-0004>Started server: "C:\Programme\PROGRESS\bin\_proapsv.exe" -ubpid 2180 -Ms 1 -logname sc2_as -logfile "d:\swisscare\sc2_as.server.log" -logginglevel 2 -logentrytypes 0 -ASID 4 -ubpropfile "C:\Programme\PROGRESS\properties\ubroker.properties" (8108)
S-0004>(20.09.2004 10:14:07:296) Message from server : Startup Procedure Failed (8113)
S-0004>(20.09.2004 10:14:07:312) IOException reading message from server : java.io.EOFException: pipe to server broken (8117)
S-0004>(20.09.2004 10:14:07:312) ERROR: cannot start server. (8100)
S-0005>Started server: "C:\Programme\PROGRESS\bin\_proapsv.exe" -ubpid 2180 -Ms 1 -logname sc2_as -logfile "d:\swisscare\sc2_as.server.log" -logginglevel 2 -logentrytypes 0 -ASID 5 -ubpropfile "C:\Programme\PROGRESS\properties\ubroker.properties" (8108)
S-0005>(20.09.2004 10:14:08:296) Message from server : Startup Procedure Failed (8113)
S-0005>(20.09.2004 10:14:08:312) IOException reading message from server : java.io.EOFException: pipe to server broken (8117)
S-0005>(20.09.2004 10:14:08:312) ERROR: cannot start server. (8100)
L-21030>(20.09.2004 10:14:09:125) Exception unbinding broker (not bound) : sc2_as (8525)
main>(20.09.2004 10:14:10:125) ubroker v91D (14-Apr-03) done. (8041)
main>(20.09.2004 10:14:10:140) Log Closed
main>(20.09.2004 10:24:11:843) d:\swisscare\sc2_as.broker.log opened.
main>(20.09.2004 10:24:11:890) ubroker version: v91D (14-Apr-03) (8038)
L-21030>(20.09.2004 10:24:11:937) Started listener thread: L-21030 (8043)
S-0001>(20.09.2004 10:24:11:984) Started server thread: S-0001. (8101)
S-0002>(20.09.2004 10:24:12:093) Started server thread: S-0002. (8101)
S-0003>(20.09.2004 10:24:12:218) Started server thread: S-0003. (8101)
S-0004>(20.09.2004 10:24:12:296) Started server thread: S-0004. (8101)
S-0005>(20.09.2004 10:24:12:390) Started server thread: S-0005. (8101)
S-0001>Started server: "C:\Programme\PROGRESS\bin\_proapsv.exe" -ubpid 596 -Ms 1 -logname sc2_as -logfile "d:\swisscare\sc2_as.server.log" -logginglevel 2 -logentrytypes 0 -ASID 1 -ubpropfile "C:\Programme\PROGRESS\properties\ubroker.properties" (8108)
S-0001>(20.09.2004 10:24:12:843) Message from server : Startup Procedure Failed (8113)
S-0001>(20.09.2004 10:24:12:843) IOException reading message from server : java.io.EOFException: pipe to server broken (8117)
S-0001>(20.09.2004 10:24:12:859) ERROR: cannot start server. (8100)
S-0002>Started server: "C:\Programme\PROGRESS\bin\_proapsv.exe" -ubpid 596 -Ms 1 -logname sc2_as -logfile "d:\swisscare\sc2_as.server.log" -logginglevel 2 -logentrytypes 0 -ASID 2 -ubpropfile "C:\Programme\PROGRESS\properties\ubroker.properties" (8108)
S-0002>(20.09.2004 10:24:13:656) Message from server : Startup Procedure Failed (8113)
S-0002>(20.09.2004 10:24:13:656) IOException reading message from server : java.io.EOFException: pipe to server broken (8117)
S-0002>(20.09.2004 10:24:13:656) ERROR: cannot start server. (8100)
S-0003>Started server: "C:\Programme\PROGRESS\bin\_proapsv.exe" -ubpid 596 -Ms 1 -logname sc2_as -logfile "d:\swisscare\sc2_as.server.log" -logginglevel 2 -logentrytypes 0 -ASID 3 -ubpropfile "C:\Programme\PROGRESS\properties\ubroker.properties" (8108)
S-0003>(20.09.2004 10:24:14:671) Message from server : Startup Procedure Failed (8113)
S-0003>(20.09.2004 10:24:14:671) IOException reading message from server : java.io.EOFException: pipe to server broken (8117)
S-0003>(20.09.2004 10:24:14:671) ERROR: cannot start server. (8100)
S-0004>Started server: "C:\Programme\PROGRESS\bin\_proapsv.exe" -ubpid 596 -Ms 1 -logname sc2_as -logfile "d:\swisscare\sc2_as.server.log" -logginglevel 2 -logentrytypes 0 -ASID 4 -ubpropfile "C:\Programme\PROGRESS\properties\ubroker.properties" (8108)
S-0004>(20.09.2004 10:24:15:656) Message from server : Startup Procedure Failed (8113)
S-0004>(20.09.2004 10:24:15:671) IOException reading message from server : java.io.EOFException: pipe to server broken (8117)
S-0004>(20.09.2004 10:24:15:671) ERROR: cannot start server. (8100)
S-0005>Started server: "C:\Programme\PROGRESS\bin\_proapsv.exe" -ubpid 596 -Ms 1 -logname sc2_as -logfile "d:\swisscare\sc2_as.server.log" -logginglevel 2 -logentrytypes 0 -ASID 5 -ubpropfile "C:\Programme\PROGRESS\properties\ubroker.properties" (8108)
S-0005>(20.09.2004 10:24:16:656) Message from server : Startup Procedure Failed (8113)
S-0005>(20.09.2004 10:24:16:671) IOException reading message from server : java.io.EOFException: pipe to server broken (8117)
S-0005>(20.09.2004 10:24:16:671) ERROR: cannot start server. (8100)
L-21030>(20.09.2004 10:24:17:531) Exception unbinding broker (not bound) : sc2_as (8525)
main>(20.09.2004 10:24:18:531) ubroker v91D (14-Apr-03) done. (8041)
main>(20.09.2004 10:24:18:531) Log Closed
when i stop the appserver and try to restart it, it doesn´t reacts. i can´t even open the status dialog. i would be glad about every help you can give.
thx
seb
thx
seb
