Production Issue Need Urgent Help
Mike
Moderator
Dear Tom,
Please help me out very urgent issue.
Progress Version= 9.1D
OS version=7.1
The Webspeed broker unable to start :-(
i checked broker log and server .log file getting this errorupload_2017-1-23_18-26-32.png
main>(Jan 23, 2017 18:18:36:132) /appln/prog91d/wrk/mfgprod.broker.log opened.
main>(Jan 23, 2017 18:18:36:157) ubroker version: v91D (23-Apr-04) (8038)
L-8097>(Jan 23, 2017 18:18:36:216) Started listener thread: L-8097 (8043)
L-8097>Starting 3 server threads ... (8053)
S-0001>(Jan 23, 2017 18:18:36:232) Started server thread: S-0001. (8101)
S-0002>(Jan 23, 2017 18:18:36:334) Started server thread: S-0002. (8101)
S-0003>(Jan 23, 2017 18:18:36:435) Started server thread: S-0003. (8101)
S-0001>Started server: /appln/prog91d/dlc/bin/jvmStart /appln/prog91d/dlc/bin/_progres -ubpid 12058650 -web -wtbhostname 156.5.238.69 -wtbport 50740 -wtaminport 3202 -wtamaxport 3502 -wtbname mfgprod -wtainstance 1 -ubpropfile /appln/prog91d/dlc/properties/ubroker.properties -logname mfgprod -p web/objects/web-disp.p -weblogerror -db mfgprod -ld qaddb -H aviance -S mfgprod -N TCP -db irisnew -ld newage -H aviance -S irisnet -N TCP (8108)
S-0002>Started server: /appln/prog91d/dlc/bin/jvmStart /appln/prog91d/dlc/bin/_progres -ubpid 12058650 -web -wtbhostname 156.5.238.69 -wtbport 50741 -wtaminport 3202 -wtamaxport 3502 -wtbname mfgprod -wtainstance 2 -ubpropfile /appln/prog91d/dlc/properties/ubroker.properties -logname mfgprod -p web/objects/web-disp.p -weblogerror -db mfgprod -ld qaddb -H aviance -S mfgprod -N TCP -db irisnew -ld newage -H aviance -S irisnet -N TCP (8108)
S-0003>Started server: /appln/prog91d/dlc/bin/jvmStart /appln/prog91d/dlc/bin/_progres -ubpid 12058650 -web -wtbhostname 156.5.238.69 -wtbport 50747 -wtaminport 3202 -wtamaxport 3502 -wtbname mfgprod -wtainstance 3 -ubpropfile /appln/prog91d/dlc/properties/ubroker.properties -logname mfgprod -p web/objects/web-disp.p -weblogerror -db mfgprod -ld qaddb -H aviance -S mfgprod -N TCP -db irisnew -ld newage -H aviance -S irisnet -N TCP (8108)
S-0002>(Jan 23, 2017 18:20:07:575) Timeout while listening for server : java.net.SocketTimeoutException: Accept timed out
S-0002>(Jan 23, 2017 18:20:07:576) ERROR: cannot start server. (8100)
S-0003>(Jan 23, 2017 18:20:08:580) Timeout while listening for server : java.net.SocketTimeoutException: Accept timed out
S-0003>(Jan 23, 2017 18:20:08:581) ERROR: cannot start server. (8100)
L-8097>(Jan 23, 2017 18:20:08:606) Exception unbinding broker (not bound) : mfgprod (8525)
main>(Jan 23, 2017 18:20:09:612) ubroker v91D (23-Apr-04) done. (8041)
main>(Jan 23, 2017 18:20:09:613) Log Closed
/appln/prog91d/wrk>
Please do needful its a Production issue.
Business impacting.
with regards
Mike :-(
TomBascom
Curmudgeon
Perhaps you ought to consider having a support contract with someone?
As I recall -- the last time you had an issue like this we spent a few days dragging the details out of you and it ultimately turned out that the host name was wrong.
I seem to recall that it ended up that it was spelled differently in /etc/hosts
Rob Fitzpatrick
WebSpeed Agent fails to start staying in 'STARTING' status
Trying to start webspeed agents fails with error(6396)
WTA: npp_enable_connections() failed with error number: -12. (6396)
Knowledge Article
Mike
Moderator
Dear Rob ,
Thank you for your suggestion , but why this java error:-
any idea:-
/appln/prog91d/wrk>
Mike
Moderator
Dear Tom ,
any idea:-
Rob Fitzpatrick
The knowledgebase article I linked to describes your exact error message, why it happens, and what to do about it.
Mike
Moderator
Dear Rob ,
########### ADDED FOR AVIANCE ###########################
[UBroker.WS.mfgprod]
appserviceNameList=mfgprod
brokerLogFile=$WRKDIR/mfgprod.broker.log
controllingNameServer=NS1
description=A sample WebSpeed Transaction Server
environment=mfgprod
fileUploadDirectory=
groupName=
initialSrvrInstance=3
minSrvrInstance=1
maxSrvrInstance=8
priorityWeight=10
autoStart=1
portNumber=8097
PROPATH=/appln/mfgproeb91c:/appln/mfgproeb91c/us/xrc:/appln/mfgproeb91c/us:/appln/mfgproeb91c/conv/dmpprocs:/appln/mfgproeb91c/xmfgusrc:/appln/mfgproeb91c/us/bbi:/a
ppln/hlnportal/irisnet:/appln/hlnportal/irisnet/online
srvrLogFiLe=$WRKDIR/mfgprod.server.log
srvrAppMode=Production
srvrstartupParam=-p web/objects/web-disp.p -weblogerror -db mfgprod -ld qaddb -H aviance -S mfgprod -N TCP -db irisnew -ld newage -H aviance -S irisnet -N TCP
userName=
uuid=a2190968b73ada0e:31a15b27:116904c392d:-8000
[Environment.mfgprod]
So where i need to add srvrMaxPort=
srvrMinPort=
Mike
Moderator
Dear Rob ,
environment=mfgprod
groupName=
minSrvrInstance=1
maxSrvrInstance=8
priorityWeight=10
autoStart=1
portNumber=8097
userName=
srvrMinPort=
Stefan
Well-Known Member
The parent of [UBroker.WS.mfgprod] is [UBroker.WS] - any property which is not provided by the child will use the property of the parent.
The parent of [UBroker.WS] is [UBroker] - from a 9.1D ubroker.properties I happen to have lying around:
 # Default properties for all unified broker instances
[UBroker]
    srvrLogThreshold=0
    srvrMaxPort=3502
    srvrMinPort=3202
    srvrStartupTimeout=3
TomBascom
Curmudgeon
If the problem is that multiple webspeed brokers are using the same port range then the solution should be to add the parameters to the children -- and for each child to use different ranges.
Rob Fitzpatrick
Agreed. Even a single AppServer or WebSpeed instance should use a discrete non-default server port range. Because today's one-and-only broker may well be tomorrow's one-of-many broker. It's simple and it's a best practice. Knowing that, there's no good reason not to do it.
