Hi,
Thank you very much for your quick reply.
When i am creating the DSN it is working fine. Our VB application is able to connect through it. But it is going to hang after a certain period of time.
Here is my startup script:
$DLC/bin/_mprosrv /data2/ebdata/lbbleba -H risc -S 1027 -N tcp -L 71680 -n 150 -c 450 -B 1024
Here is my DB log file:
06:05:48 BROKER 0: Multi-user session begin. (333)
06:05:50 BROKER 0: Started for 1027 using tcp, pid 631022. (5644)
06:05:51 BROKER 0: PROGRESS Version 9.1B on AIX. (4234)
06:05:51 BROKER 0: Server started by root on batch. (4281)
06:05:51 BROKER 0: Started using pid: -24338. (6574)
06:05:51 BROKER 0: Physical Database Name (-db): /data2/ebdata/lbbleba. (4235)
06:05:51 BROKER 0: Database Type (-dt): PROGRESS. (4236)
06:05:51 BROKER 0: Force Access (-F): Not Enabled. (4237)
06:05:51 BROKER 0: Direct I/O (-directio): Not Enabled. (4238)
06:05:51 BROKER 0: Number of Database Buffers (-B): 1024. (4239)
06:05:51 BROKER 0: Excess Shared Memory Size (-Mxs): 16428. (4240)
06:05:51 BROKER 0: Current Size of Lock Table (-L): 71680. (4241)
06:05:51 BROKER 0: Hash Table Entries (-hash): 317. (4242)
06:05:51 BROKER 0: Current Spin Lock Tries (-spin): 0. (4243)
06:05:51 BROKER 0: Number of Semaphore Sets (-semsets) 1. (6526)
06:05:51 BROKER 0: Crash Recovery (-i): Enabled. (4244)
06:05:51 BROKER 0: Database Blocksize (-blocksize): 8192. (6573)
06:05:51 BROKER 0: Delay of Before-Image Flush (-Mf): 3. (4245)
06:05:51 BROKER 0: Before-Image File I/O (-r -R): Reliable. (4247)
06:05:51 BROKER 0: Before-Image Truncate Interval (-G): 60. (4249)
06:05:51 BROKER 0: Before-Image Cluster Size: 524288. (4250)
06:05:51 BROKER 0: Before-Image Block Size: 8192. (4251)
06:05:51 BROKER 0: Number of Before-Image Buffers (-bibufs): 5. (4252)
06:05:51 BROKER 0: BI File Threshold size (-bithold): 0.0 Bytes. (9238)
06:05:51 BROKER 0: BI File Threshold Stall (-bistall): Disabled. (6552)
06:05:51 BROKER 0: After-Image Stall (-aistall): Not Enabled. (4254)
06:05:51 BROKER 0: Number of After-Image Buffers (-aibufs): 5. (4256)
06:05:51 BROKER 0: Storage object cache size (-omsize): 1024 (8527)
06:05:51 BROKER 0: Maximum Number of Clients Per Server (-Ma): 37. (4257)
06:05:51 BROKER 0: Maximum Number of Servers (-Mn): 5. (4258)
06:05:51 BROKER 0: Minimum Clients Per Server (-Mi): 1. (4259)
06:05:51 BROKER 0: Maximum Number of Users (-n): 151. (4260)
06:05:51 BROKER 0: Host Name (-H): risc. (4261)
06:05:51 BROKER 0: Service Name (-S): 1027. (4262)
06:05:51 BROKER 0: Network Type (-N): tcp. (4263)
06:05:51 BROKER 0: Character Set (-cpinternal): ISO8859-1. (4264)
06:05:51 BROKER 0: Parameter File: Not Enabled. (4282)
06:05:51 BROKER 0: Minimum Port for Auto Servers (-minport): 1025. (5648)
06:05:51 BROKER 0: Maximum Port for Auto Servers (-maxport): 2000. (5649)
06:05:51 BROKER 0: This broker supports both 4GL and SQL server groups. (8865)
06:05:51 BROKER 0: Created shared memory with segment_id: 7 (9336)
10:54:00 BROKER 0: Shared Library Path set to LIBPATH=/data1/appln/pro91b/lib
10:54:00 SQLSRV2 1: SQL Server 9.1b started, configuration: "lbbleba.virtualconfig"
10:54:00 SQLSRV2 1: "/data2/ebdata/lbbleba" started on port 1025, pid 1085476 (0x00109024).
We have another Server for Test Environment. It is running through Progress V9.1D.
But this Progress driver(Merant 3.60 32-bit Progress SQL92) is working fine with it.
Thank You.
