Using OCX's without a smart container
Chris Kelleher
Administrator
Staff member
Hi All.
Can anyone tell me how load an OCX without having to use a SmartContainer
like a Smartwindow. The environment in question is v8.3A using Windws 95.
Incidentally, can someone tell me which image format the DOTR LoadImage OCX
expects.
TIA.
Ray Atherton
Cornerstone Systems
Brisbane, Australia
Chris Kelleher
Administrator
Staff member
At 11:49 AM 10/7/99 +1000, Ray Atherton wrote:
>Hi All.
You must use the UIB to generate the .WRX. Then have a look inside
some UIB generated code to see how the controls are initialized
in the IP.
>expects.
It creates something called an image list. It doesn't really
expect any particular image type. It's what ever's going to
use the image list that you have to worry about.
Geoff Crawford Phone: (973) 361 - 4224
Innovative Client Servers FAX: (973) 537 - 6946
75 Fleetwood Drive, Suite 200 Email: geoff@innov8cs.com
Rockaway NJ 07886 Web: http://www.innov8cs.com
One World, One PEG
Chris Kelleher
Administrator
Staff member
It is not necessary to use a SmartContainer.
You can use the UIB (AppBuilder in V9) to
place an OCX into an ordinary frame.
There are only a few simple rules governing database
design. Unfortunately, too few people know what they are.
Ted Duke
PEG Member: 1998013001 --- Consulting/Training/Design
TJD Enterprises, Inc--Box 2246--Reston VA USA 20195-0246
Tel
703)318-8502--Fax: (419) 793-7395--email: tedduke@erols.com
Chris Kelleher
Administrator
Staff member
AFAIK, it doesn't create the image list. It just adds an image
to an existing image list.
So you also need to create the Microsoft ImageList (from
comctl32.ocx) and pass the handle of this ImageList to the
LoadImage OCX:
chLoadImage:LoadImage(chImageList, vcFile).
HTH
Uwe.
