C
Cristina K
I am using SQL in Excel, my query has a UNION statement and I need to order by date.
I have 3 tables: "Work_order_0", "Work_history_0" and "Note_0". "Work_0rder_0" and "Work_history_0" have the same fields.
My code is:
SELECT Work_order_0.WO_Key AS 'WO key',
Work_order_0.Pos_key AS 'POS key',
Work_order_0.Order_date AS 'Order date',
Work_order_0.Order_time/86400 AS 'Order time',
Note_0.Note AS 'Note'
FROM API3.PUB.Work_order Work_order_0
LEFT JOIN API3.PUB.Note Note_0 ON Work_order_0.WO_Key=Note_0.Relate_key
UNION
SELECT Work_history_0.WO_Key AS 'WO key',
Work_history_0.Pos_key AS 'POS key',
Work_history_0.Order_date AS 'Order date',
Work_history_0.Order_time/86400 AS 'Order time',
FROM API3.PUB.Work_history Work_history_0
LEFT JOIN API3.PUB.Note Note_0 ON Work_history_0.WO_Key=Note_0.Relate_key
ORDER BY 'Order date' DESC;
As you can see in the last line, I tried using an alias in the ORDER BY clause but it gives me the following error
Bad field specification in order by clause (7645)
Any suggestions? Thanks in advance.
My code is:
UNION
