W
W0lfw00ds
I know there's way to get static buffer's table name with this:
Is there a similar way to get
I would like to use
DEF BUFFER Customer_B1 FOR Customer.
DEF VAR cTableName AS CHAR NO-UNDO.
cTableName = BUFFER Customer_B1:HANDLE:TABLE.
buffer field handle
and it's field name using static reference?I would like to use
static buffers
because they are checked at compile time against the configured database. This means that if some table or field is missing, the codes won't compile. I wouldn't like to use field number or string names to get the field handle.Continue reading...
