Dominique
As mentioned before in some questions with "Progress-4GL" and "OpenEdge" tags, I'm working with AppBuilder and Procedure editor. As a result, the debugging possibilities are extremely limited: for knowing the value of a variable, I need to do show them on screen, something like this:
I can also put that information in a logfile, but that's not the main point here.
I would like to write a procedure, which can handle this, something like:
Does anybody know how to handle the fist two points (put variable name and value together and handle an unknown number of input parameters)?
Thanks in advance
MESSAGE "temp1=[" temp1 "], temp2=[" temp2 "]" VIEW-AS ALERT-BOX.
PROCEDURE SHOW_VARIABLES_AND_VALUES (INPUT I1, INPUT I2, ...):
1. <put parameter names and values together inside one string> => """I1="" I1"
2. <do this for all input parameters (the number is unknown)> => """I1="" I1, ""I2="" I2, ..."
3. <how to use this (MESSAGE VIEW-AS ALERT-BOX, LOG, ...) there I'll know what to do>
Thanks in advance
