Thiru
I am new to progress 4GL. I have written logic for buffer by adding multiple tables into a single query and finding the records from another table by using table field names. I am not sure why I am getting errors. Please help to change the logic
DEFINE VARIABLE ix AS INTEGER NO-UNDO.
DEFINE VARIABLE qh AS HANDLE NO-UNDO.
DEFINE VARIABLE bh AS HANDLE NO-UNDO.
DEFINE VARIABLE fh AS HANDLE NO-UNDO EXTENT 10.
DEFINE VARIABLE cQuery AS CHARACTER NO-UNDO.
CREATE BUFFER bh FOR TABLE "Customer, Invoice".
CREATE QUERY qh.
ASSIGN
cQuery = "FOR EACH Customer NO-LOCK, EACH Invoice WHERE Invoice.Cust-Num = Customer.Cust-
Num NO-LOCK: ".
qh:SET-BUFFERS(bh).
qh:QUERY-PREPARE(cQuery).
qh:QUERY-OPEN().
qh:GET-FIRST().
/* Field Invoice.Cust-Num is already defined in cQuery*/
FIND Order WHERE Order.Cust-Num = Invoice.Cust-Num NO-LOCK NO-ERROR.
IF NOT AVAILABLE Order THEN DO:
FIND Ref-Call WHERE Ref-Call.Cust-Num = Invoice.Cust-Num NO-LOCK NO-ERROR.
DISPLAY Ref-Call.Cust-Num.
END.
qh:QUERY-CLOSE().
bh:BUFFER-RELEASE().
DELETE OBJECT bh.
DELETE OBJECT qh.
