AbhayShukla
Hi,
One of our client is connected to our progress 10.2B database through a JDBC client(eclipse).
He has created some triggers(as SQL client) on a table which already has 4GL triggers on create, update, delete events .
As per KB if a 4gl application causes an event then 4GL triggers are fired by DB not sql triggers.
it furthur says that SQL client commands are taken care by SQL-92 engine while 4GL triggers by 4gl engine.
Our client wants both SQL and 4GL to be fired in any event.
Is it possible ?
or i have a incorrect impression of triggers .
OS: Windows XP.
Thanks........
Is it possible ?
OS: Windows XP.
Thanks........
