I'm working on fixing our compiler tooling for OpenEdge ABL projects. There was a problem related to the concurrent compilation into a shared working directory (one used by other active ABL sessions). There is another separate post that discusses these concurrency conflicts : SYSTEM ERROR: I/O error 2 while compiling code - Forum - OpenEdge Development - Progress Community Now I'm using the SAVE INTO parameter as suggested by Frank Meulblok. Here are the docs OpenEdge 11.7 Documentation The unfortunate thing I'm discovering about this approach is that p-code and cls-code are treated differently! For cls-code, the compiler will create the missing directory structures and place compiled code in them once they are set in place. However for p-code the compiler will *not* create the subdirectories and will simply generate error messages like the following (whereby the "app\Maintenance\Shipping" portion of the path wasn't created ahead of time). Unable to create r-code file "C:\whatever\TempCompilation_v011\app\Maintenance\Shipping\FuelSurcharge.r". (477) So it is unfortunate that I have to create my output directories ahead of time for some portions of the codebase and not others. Here is the part of the docs that describes the behavior when compiling classes. (it doesn't seem to apply to p-code) When you use the SAVE INTO phrase to store compiled r-code files for one or more class definition files specified with a package, ABL creates a directory structure under the specified SAVE INTO directory that is consistent with the directory structure of the original source files relative to PROPATH (if the directory structure doesn't already exist). That is, ABL creates a subdirectory under the specified SAVE INTO directory to match the original source directory for each class definition file in the hierarchy. I'm assuming this difference in behavior is expected? Is there a good reason for the difference in behavior between p-code and cls-code? I'm assuming cls-code is more "strict" about matching folder structures and namespaces, so it takes the initiative to create folders. Whereas the legacy p-code behavior is closely tied to PROPATH, and so it doesn't presume to know where you want your r-code saved. Is that the idea? Interestingly the XREF-XML output feature will create full directory structure and that does *not* seem to work differently for p-code vs cls-code. When a directory is supplied, the compiler takes the root name of the procedure or class being compiled and creates a cross-reference file with this name and a .xref.xml file extension (sourcefilename.xref.xml). It stores it in the directory path specified, creating any necessary subdirectories that do not exist. For now I will assume that I need to create all my own subdirectories in order for the "SAVE INTO" behavior to work for both p-code and cls-code. I think the approach I will use is probably to create empty directories with xcopy /t /e. Please let me know if I'm using "SAVE INTO" incorrectly, or overlooking something in the COMPILE statement that will create my directories for me. Here is is where xcopy is mentioned as a way to create directories: Copy folder structure on Windows
