[progress Communities] [progress Openedge Abl] Forum Post: Re: [technical Users - Use Of...
mparish
Correct For some reason the syntax is not supported as a database filter but I’m not sure what the technical reason is. The alternative is to use this syntax which could get rather lengthy if you have a lot of values to test. Mike From: Gertjan H [mailto:bounce-hendrige@community.progress.com] Sent: Wednesday, December 07, 2016 10:04 AM To: TU.Corticon@community.progress.com Subject: RE: [Technical Users - Corticon] Can i get the correct range and set format for using 'in' and 'charsIn' operators? Update from Progress Community Gertjan H Thanks Mike! This only seems to work though as a regular Filter or Precondition, but *not* as a Database Filter (with EDC). A Database Filter will cause the error-message "Filter Expression cannot be processed by the database". Is there any other way to use the "not in" within EDC? Thanks! :) -Gertjan View online You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here . Flag this post as spam/abuse.
