P
Peter Judge
The ABL HTTP Client can make the calls you need for both getting the token and for passing it. There are a number of examples on Github at github.com/.../http_client . It’s relatively simple to construct requests and consume responses in general. For this kind of API call, you need to be careful about how you build the token (the x-csod-signature header value). Look at using the MESSAGE-DIGEST() function to perform the SHA-512 hashing .
