[progress Communities] [progress Openedge Abl] Forum Post: Re: Source Management Solution :...
Jeff Ledbetter
Hi. I suspect that your customized UI is limiting your access to all Roundtable TSMS features. Out of the box, Roundtable TSMS provides Cross-reference and Where-used views for your ABL source-code and schema that tell you what Objects related and how they are related. In fact, I don't know of many tools that can provide you with this much information with a single click. This screenshot (Roundtable TSMS 11.6) is from our plug-in but the same information is available in our GUI client as well. The Roundtable Automation Toolkit is a framework to integrate Roundtable with Jenkins and provides some pre-built scripts to integrate the two tools with a templates to create your own. It can be found on our Downloads page: www.roundtable-software.com/.../ The documentation resides here: https://confluence.nodeable.io/display/ARAT One could use the Roundtable event hooks to replicate data into a third-party code-motel like SVN. The event hook documentation can be found in the rtb_events.p procedure. A white-paper on using our event hooks and API can be found here: http://www.roundtable-software.com/roundtable/resource/pdf/wp/HooksAPIforOA.pdf All Roundtable TSMS documentation can be found here: http://www.roundtable-software.com/support/documentation/ To discuss your requirements in more detail, please contact me directly.
