[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Pro2 and deactivate delete procedure
K
Ken McIntosh
Hi Jarmo, Are you talking about auditing maybe? If that is available in the Oracle database you might consider that. If you're just talking about marking records as deleted you could definitely customize the Pro2 code to do that. Like Laurent says, it's ABL. You would have to make sure you re-implement your changes in future releases. In the meantime you could log an Enhancement Request (Idea) for a feature that would allow automatically marking records as deleted in the target. Presently there is an auditing feature in Pro2 which avoids deleting the replication queue record in order to post it again to a second target, but this will still apply the deletion to both targets. The below article tells you how to log an Idea: knowledgebase.progress.com/.../P11255 Best Regards, Ken McIntosh
