P
Peter Judge
If you see that message returned, without any 'real' errors , then it's possibly bad or missing configuration. The internal component that runs the webhandle can log which handler is used for URI. You'll need to have a logging level of at least 5 (set via -loggingLevel 5) . logger: Debug ( substitute ( 'Request for path "&1" using template "&2" and handler "&3"' , requestPath, uriTemplate, pcHandlerName)). That should at least help clear that part up.
