B
Brian Derwart
John, The behavior you describe here certainly sounds unexpected. By default, the job you ran should have created packages in the NULLID schema and then granted permissions on them to PUBLIC. Are all your users in the PUBLIC schema? Upon connecting to the server, the driver issues a query against the SYSIBM.SYSPACKAGE table to check for the existence of the packages and if they're not found, it will try to create them. Do your users have SELECT privileges on this table? If the query against the SYSPACKAGE table fails, then the driver will assume the packages do not exist and try to create them. This might explain why you are seeing the driver try to create the required packages for every user that connects. It is not expected for you to grant BINDADD and CREATE IN to your individual users. Package creation is something of an expensive process, so the expectation is that it is done once and then the packages are simply available for the drivers to utilize. Please check on the items listed above and let me know what you find.
