jread
Is Ohio created under Categories or is it part of a custom Classification? TaxonomyId is tied to Classifications, you can retrieve them from this endpoint /api/default/taxonomies. So if Ohio is created under Categories use the idea for that taxon, if you created a "custom" classification use the id from the custom classification, i.e. States. ParentId would be the Id of the Ohio taxon when creating cincinnati and can be retrieved from Use POST /api/default/hierarchy-taxa to create the Cincinnati endpoint You do not need to include the / in the UrlName as it will result in an error.
