[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Issues with PAS and network connectivity
Did you fix the crashing while the ABL is interacting with the database? That seemed like the biggest concern! (And one that should NOT have anything to do with your particular infrastructure). It seems like that would be affecting *all* PASOE customers who are using shared memory connections to their databases. I'm surprised that type of problem hasn't been reported before... How are the remote APSV connections made? From the .net or java openclient? Also do you have the "HTTP sessions" enabled? (Which are unrelated to the "ABL sessions" within an msagent.) You might want to take measurements of how long it takes before client connections are broken. Some of this might be related to tomcat timeouts or some such thing. We had trouble with this as well, and the troubles are based on the differences in the way that sessions are managed in classic vs PASOE.
