[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Generating PCT ClassDocumentation from Jenkins
Stefan Drissen
From the help button on the "Java Options" field: If your build requires a custom ANT_OPTS, specify it here. Typically this may be used to specify java memory limits to use, for example -Xmx512m. Note that other Ant options (such as -lib) should go to the "Ant targets" field.
