V
victorche
Hi Laura, Thank ypu for your answers! I'll try the events you suggested. I'll try to explain. For example, I connect to the sports2000 database. Then create a temporary tDep table like sports2000 table.department. Then I fill in the temporary table via ProDataSet. And then bind the filled table to ProBindignSource, which is associated with the RadGridView element. The AllowEditRow property for RadGridView is set to TRUE. As a result, I get the data in RadGridView successfully. Now I double-click to edit the Dep Name field in RadGridView for any record and change its contents. Now I want to save the change by pressing Enter or just clicking on any area of the grid. But my change disappears and the old value is returned. It seems like a simple operation, but I have not found an example for its implementation.
