K
Karikalan Ram
I've problem when my dynamic query involved with more than one table. for ex, lvRowid has valid rowid value, qryhandle:IS-OPEN = TRUE iv-qryhandle:NUM-RESULTS <> 0 also TRUE, However I am not sure lRepos = qryhandle:REPOSITION-TO-ROWID(lvRowid) NO-ERROR. returns lRepos = false and ERROR-STATUS:ERROR = no. When I check qryhandle:NUM-BUFFERS value its 2, then I looked into query string as its composed with one temp-table and one db table. For ex, for each ttHeader no-lock, each dbHeader where rowid(dbHeader) = ttHeader.Headerrowid. I suspect since this query uses two different buffer when I use Reposition-to-rowid system unable to locate right buffer. Could someone pls suggest generic solution on this? Also when {&file} as dbtable name ex., dbHeader statements BUFFER {&file}:handle = qryhandle{&brwsfx}:GET-BUFFER-HANDLE(1) value as FALSE BUFFER {&file}:handle = qryhandle{&brwsfx}:GET-BUFFER-HANDLE(2) value as TRUE Based on this scenario my "qryhandle:REPOSITION-TO-ROWID(lv-FileRowId)" should be applied on Buffer-HANDLE(2). My question here how do we specify/set current buffer handle as 2 to trigger reposition-to-rowed?
