C
cverbiest
This is about Tech support case 00354702. We had a first crash last Thurday. at this moment we're down for the 4rd or 5th time today. This is the same system mentioned in https://community.progress.com/community_groups/openedge_rdbms/f/18/t/26051 Following progress tech support we already increased tha maximum open file to 65536 I decreased -Mm backup to it's default of 1024 We had 2 databases running, stopped on of the databases increased kernel.sem from 560 32000 200 2048 to kernel.sem = 560 32000 200 4096 none of these steps helped [root@franky-db applprod]# cat /etc/redhat-release CentOS Linux release 7.2.1511 (Core) [root@franky-db applprod]# cat $DLC/version OpenEdge Release 11.6.1 as of Fri Feb 19 18:20:45 EST 2016 [2016/07/20@19:33:03.387+0200] P-28172 T-140407840053056 I SRV 5: (7129) Usr 187 set name to magfr. [2016/07/20@19:46:25.516+0200] P-18869 T-140677741020992 I APPSRV 91: (1132) Invalid semaphore id [2016/07/20@19:46:25.516+0200] P-18867 T-139917784467264 I APPSRV 87: (1132) Invalid semaphore id [2016/07/20@19:46:25.516+0200] P-18869 T-140677741020992 I APPSRV 91: (10839) SYSTEM ERROR: Unable to set semaphore set : semid = 7, errno = 22. [2016/07/20@19:46:25.516+0200] P-18869 T-140677741020992 I APPSRV 91: (453) Logout by apsrv_agent on batch. [2016/07/20@19:46:25.516+0200] P-18869 T-140677741020992 I APPSRV (1132) Invalid semaphore id [2016/07/20@19:46:25.516+0200] P-18869 T-140677741020992 I APPSRV (10839) SYSTEM ERROR: Unable to get value of semaphore set : semid = 5, errno = 22. [2016/07/20@19:46:25.516+0200] P-18869 T-140677741020992 I APPSRV (-----) semLockLog_2: semValue val = -1 [2016/07/20@19:46:25.516+0200] P-18867 T-139917784467264 I APPSRV 87: (10839) SYSTEM ERROR: Unable to set semaphore set : semid = 7, errno = 22. [2016/07/20@19:46:25.516+0200] P-18867 T-139917784467264 I APPSRV 87: (453) Logout by apsrv_agent on batch. [2016/07/20@19:46:25.516+0200] P-18867 T-139917784467264 I APPSRV (1132) Invalid semaphore id [2016/07/20@19:46:25.516+0200] P-18867 T-139917784467264 I APPSRV (10839) SYSTEM ERROR: Unable to get value of semaphore set : semid = 5, errno = 22. [2016/07/20@19:46:25.516+0200] P-18867 T-139917784467264 I APPSRV (-----) semLockLog_2: semValue val = -1 [2016/07/20@19:46:25.517+0200] P-18879 T-139704148830016 I APPSRV 93: (1132) Invalid semaphore id [2016/07/20@19:46:25.517+0200] P-18879 T-139704148830016 I APPSRV 93: (10839) SYSTEM ERROR: Unable to set semaphore set : semid = 7, errno = 22. [2016/07/20@19:46:25.517+0200] P-18879 T-139704148830016 I APPSRV 93: (453) Logout by apsrv_agent on batch. [2016/07/20@19:46:25.517+0200] P-18879 T-139704148830016 I APPSRV (1132) Invalid semaphore id [2016/07/20@19:46:25.517+0200] P-18879 T-139704148830016 I APPSRV (10839) SYSTEM ERROR: Unable to get value of semaphore set : semid = 5, errno = 22. [2016/07/20@19:46:25.517+0200] P-18879 T-139704148830016 I APPSRV (-----) semLockLog_2: semValue val = -1 [2016/07/20@19:46:25.517+0200] P-18889 T-140682824206144 I APPSRV 94: (1132) Invalid semaphore id [2016/07/20@19:46:25.518+0200] P-18889 T-140682824206144 I APPSRV 94: (10839) SYSTEM ERROR: Unable to set semaphore set : semid = -32762, errno = 22. [2016/07/20@19:46:25.518+0200] P-18889 T-140682824206144 I APPSRV 94: (453) Logout by apsrv_agent on batch. [2016/07/20@19:46:25.518+0200] P-18889 T-140682824206144 I APPSRV (1132) Invalid semaphore id [2016/07/20@19:46:25.518+0200] P-18889 T-140682824206144 I APPSRV (10839) SYSTEM ERROR: Unable to get value of semaphore set : semid = 5, errno = 22. [2016/07/20@19:46:25.518+0200] P-18889 T-140682824206144 I APPSRV (-----) semLockLog_2: semValue val = -1 [2016/07/20@19:46:25.518+0200] P-18891 T-139907829344064 I APPSRV 95: (1132) Invalid semaphore id [2016/07/20@19:46:25.519+0200] P-18891 T-139907829344064 I APPSRV 95: (10839) SYSTEM ERROR: Unable to set semaphore set : semid = 7, errno = 22. [2016/07/20@19:46:25.519+0200] P-18891 T-139907829344064 I APPSRV 95: (453) Logout by apsrv_agent on batch. [2016/07/20@19:46:25.519+0200] P-18891 T-139907829344064 I APPSRV (1132) Invalid semaphore id [2016/07/20@19:46:25.519+0200] P-18891 T-139907829344064 I APPSRV (10839) SYSTEM ERROR: Unable to get value of semaphore set : semid = 5, errno = 22. [2016/07/20@19:46:25.519+0200] P-18891 T-139907829344064 I APPSRV (-----) semLockLog_2: semValue val = -1 [2016/07/20@19:46:28.335+0200] P-18511 T-139941315757888 I BROKER 0: (2527) Disconnecting dead user 87. [2016/07/20@19:46:28.335+0200] P-18511 T-139941315757888 I BROKER 0: (1132) Invalid semaphore id [2016/07/20@19:46:28.335+0200] P-18511 T-139941315757888 I BROKER 0: (10839) SYSTEM ERROR: Unable to set semaphore set : semid = 7, errno = 22. [2016/07/20@19:46:28.335+0200] P-18511 T-139941315757888 I BROKER 0: (1132) Invalid semaphore id [2016/07/20@19:46:28.335+0200] P-18511 T-139941315757888 I BROKER 0: (10839) SYSTEM ERROR: Unable to get value of semaphore set : semid = 5, errno = 22. [2016/07/20@19:46:28.335+0200] P-18511 T-139941315757888 I BROKER 0: (-----) semLockLog_2: semValue val = -1 [2016/07/20@19:46:28.335+0200] P-18511 T-139941315757888 I BROKER 0: (5292) SYSTEM ERROR: The broker is exiting unexpectedly, beginning Abnormal Shutdown. [2016/07/20@19:46:28.335+0200] P-18511 T-139941315757888 I BROKER 0: (-----) drexit: Initiating Abnormal Shutdown [2016/07/20@19:17:06.846+0200] P-18511 T-139941315757888 I BROKER 0: (333) Multi-user session begin. [2016/07/20@19:17:06.852+0200] P-18511 T-139941315757888 I BROKER 0: (5326) Begin Physical Redo Phase at 1344 . [2016/07/20@19:17:07.106+0200] P-18511 T-139941315757888 I BROKER 0: (7161) Physical Redo Phase Completed at blk 1418 off 5425 upd 1870. [2016/07/20@19:17:07.106+0200] P-18511 T-139941315757888 I BROKER 0: (13547) At end of Physical redo, transaction table size is 256. [2016/07/20@19:17:07.514+0200] P-18511 T-139941315757888 I BROKER 0: (452) Login by proadmin on /dev/pts/2. [2016/07/20@19:17:07.514+0200] P-18511 T-139941315757888 I BROKER 0: (5644) Started for 11000 using TCP IPV4 address 0.0.0.0, pid 18511. [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (4234) Progress OpenEdge Release 11.6 build 1296 SP01 on Linux franky-db 3.10.0-327.el7.x86_64 #1 SMP Thu Nov 19 22:10:57 UTC 2015 x86_64. [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (4281) Server started by proadmin on /dev/pts/2. [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (6574) Started using pid: 18511. [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (15219) Encryption enabled: 0 [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (15824) Multi-tenancy enabled: 0 [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (15824) Table Partitioning enabled: 0 [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (-----) LRU mechanism enabled. [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (4282) Parameter File: Not Enabled. [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (9336) Created shared memory with segment_id: 98306 [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (4250) Before-Image Cluster Size: 524288. [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (4251) Before-Image Block Size: 8192. [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (13873) After-image Management Archival Directory List (-aiarcdir): Not Enabled [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (13874) Create After-image Management Archival Directory(s) (-aiarcdircreate): Not Enabled [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (13872) After-image Management Archival Interval (-aiarcinterval): -1 [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (4256) Number of After-Image Buffers (-aibufs): 20 [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (4254) After-Image Stall (-aistall): Not Enabled [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (17555) Starting index number for statistics range (-baseindex): 1 [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (17554) Starting table number for statistics range (-basetable): 1 [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (4252) Number of Before-Image Buffers (-bibufs): 20 [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (6552) BI File Threshold Stall (-bistall): Disabled. [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (9238) BI File Threshold size (-bithold): 0.0 Bytes [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (6573) Database Blocksize (-blocksize): 8192 [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (12812) BIW writer delay (-bwdelay): 0 [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (12813) Allowed index cursors (-c): 452. [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (12265) SSL Certificate Store Path (-certstorepath): Not Enabled [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (4264) Character Set (-cpinternal): UTF-8 [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (4235) Physical Database Name (-db): /usr2/cce/applprod/data/LISA [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (4238) Direct I/O (-directio): Not Enabled [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (4236) Database Type (-dt): PROGRESS [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (15218) Encryption cache size (-ecsize): 1000 [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (12814) Group delay (-groupdelay): 10 [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (4242) Hash Table Entries (-hash): 1037347 [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (4244) Crash Recovery (-i): Enabled [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (17557) Number of indexes included in statistics collection (-indexrangesize): 2500 [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (14268) TCP/IP Version (-ipver): IPV4 [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (12263) SSL Key Alias Name (-keyalias): Not Enabled [2016/07/20@19:17:08.515+0200] P-18511 T-139941315757888 I BROKER 0: (12815) Lock table hash table size (-lkhash): 25621 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (17805) Original Lock Release Algorithm (-lkrela): Not Enabled [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (17560) Number of LRU force skips (-lruskips): 0 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (17561) Number of LRU2 force skips (-lru2skips): 0 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (13953) Maximum Area Number (-maxArea): 32000 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (12540) Size of JTA transaction table (-maxxids): 100 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (5649) Maximum Port for Auto Servers (-maxport): 12999 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (5648) Minimum Port for Auto Servers (-minport): 11001 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (17564) Multi-tenancy partition cache size (-mtpmsize): 1024 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (12821) Use muxlatches (-mux): 1 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (4260) Maximum Number of Users (-n): 113 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (17566) Minimum time to nap at first -spin exhaustion (-nap): 10 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (17565) Maximum time to nap at -spin exhaustion (-napmax): 250 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (12273) No SSL Session Cache (-nosessioncache): Not Enabled [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (17807) Disable LRU mechanism (-nolru): Not Enabled [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (16689) Login Governor (-nGovernor): 0 of 113 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (8527) Storage object cache size (-omsize): 1024 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (13870) Database Service Manager - IPC Queue Size (-pica): 64.0 KBytes [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (17802) Shared memory segments locked (-pinshm): Not Enabled [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (16953) Use pollset mechanism for client/server (-pollset): Not Enabled [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (16955) Delay first prefetch message (-prefetchDelay): Not Enabled [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (16956) Prefetch message fill percentage (-prefetchFactor): 0 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (16957) Minimum records in prefetch msg (-prefetchNumRecs): 16 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (16958) Suspension queue poll priority (-prefetchPriority): 0 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (17568) APW queue scan cycle time in milliseconds (-pwqdelay): 100 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (17569) APW minimum queue length before write (-pwqmin): 1 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (17570) APW buffer scan cycle time in seconds (-pwsdelay): 1 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (17571) APW maximum number of buffers to scan per cycle (-pwscan): 5000 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (17572) APW maximum number of buffers to write per cycle (-pwwmax): 25 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (4247) Before-Image File I/O (-r -R): Reliable [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (17563) Record free chain search depth factor (-recspacesearchdepth): 5 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (6526) Number of Semaphore Sets (-semsets): 3 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (12264) SSL Session Timeout (-sessiontimeout): 0 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (13924) Maximum Shared Memory Segment Size (-shmsegsize): 32768 Mb [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (4243) Current Spin Lock Tries (-spin): 20000 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (17803) SSL Encryption for TCP/IP connections (-ssl): Not Enabled [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (17556) Number of tables included in statistics collection (-tablerangesize): 1000 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (14017) Area block consistency check (-AreaCheck): Not Enabled [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (4239) Number of Database Buffers (-B): 3000000 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (17562) Number of Alternate Database Buffers (-B2): 0 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (9422) Maximum private buffers per user (-Bpmax): 64 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (14016) Database block consistency check (-DbCheck): Not Enabled [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (13869) Database Service Manager - Service(s) to start (-DBService): Not Enabled [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (10535) Enhanced Read-Only mode (-ERO): Not Enabled [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (4237) Force Access (-F): Not Enabled [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (4249) Before-Image Truncate Interval (-G): 0 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (4261) Host Name (-H): franky-db [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (14018) Index block consistency check (-IndexCheck): Not Enabled [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (4241) Current Size of Lock Table (-L): 150016 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (16688) Lock Governor (-LGovernor): 0% [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (4257) Maximum Number of Clients Per Server (-Ma): 1 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (14016) Memory overwrite check (-MemCheck): Not Enabled [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (4245) Delay of Before-Image Flush (-Mf): 3 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (4259) Minimum Clients Per Server (-Mi): 1 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (12818) Message Buffer Size (-Mm): 1024 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (4258) Maximum Number of Servers (-Mn): 80 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (12819) Servers per Protocol (-Mp): 0 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (5647) Maximum Servers Per Broker (-Mpb): 78 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (4240) Excess Shared Memory Size (-Mxs): 91 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (4263) Network Type (-N): TCP [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (16954) Server network message wait time (-Nmsgwait): 2 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (10357) Pending client connection timeout (-PendConnTimeout): 0 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (4262) Service Name (-S): 11000 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (17804) Broker server group support (-ServerType): ABL [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (10028) SQL Server Max Open Cursors (-SQLCursors): 0 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (10026) SQL Server Stack Size (-SQLStack): 0 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (10027) SQL Server Statement Cache Size (-SQLStmtCache): 0 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (10029) Size [1K byte units] of SQL Server temp table buffer (-SQLTempStoreBuff): 0 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (10030) Size [1K byte units] of SQL Server temp table disk storage (-SQLTempStoreDisk): 0 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (10031) Size [1K byte units] of SQL Server temp table data page (-SQLTempStorePageSize): 0 [2016/07/20@19:17:08.516+0200] P-18511 T-139941315757888 I BROKER 0: (17955) Authorized data truncation (-SQLTruncateTooLarge): OFF [2016/07/20@19:17:08.517+0200] P-18511 T-139941315757888 I BROKER 0: (18156) SQL Autonomous Schema Update (-SQLWidthUpdate): OFF [2016/07/20@19:17:08.517+0200] P-18511 T-139941315757888 I BROKER 0: (14019) Record block consistency check (-TableCheck): Not Enabled [2016/07/20@19:17:08.517+0200] P-18511 T-139941315757888 I BROKER 0: (17717) TXE Lock retry limit (-TXERetryLimit): 0 [2016/07/20@19:17:08.517+0200] P-18511 T-139941315757888 I BROKER 0: (13896) TXE Commit lock skip limit (-TXESkipLimit): 10000 [2016/07/20@19:17:08.517+0200] P-18511 T-139941315757888 I BROKER 0: (10836) Database connections are not allowed at this time. [2016/07/20@19:17:08.517+0200] P-18511 T-139941315757888 I BROKER 0: (10471) Database connections have been enabled. [2016/07/20@19:17:08.517+0200] P-18525 T-139698275055424 I BIW 80: (-----) Login by proadmin. [2016/07/20@19:17:08.518+0200] P-18525 T-139698275055424 I BIW 80: (2518) Started. [2016/07/20@19:17:08.556+0200] P-18529 T-139954100561728 I APW 81: (-----) Login by proadmin. [2016/07/20@19:17:08.557+0200] P-18529 T-139954100561728 I APW 81: (2518) Started. [2016/07/20@19:17:08.596+0200] P-18533 T-140212745291584 I APW 82: (-----) Login by proadmin. [2016/07/20@19:17:08.597+0200] P-18533 T-140212745291584 I APW 82: (2518) Started.
