[Progress Communities] [Progress OpenEdge ABL] Forum Post: Editor Widget in Down Frame
B
bfraser4070
Hello: I have 3 variables. Variable 1 is a Logical field Variable 2 is a standard character variable and will contain only 8 characters Variable 3 is a character field that could contain up to 1,000 characters I want to display these fields in a down frame. Here is my code: define frame b err_compl label "Solved" err_level label "Level" view-as editor inner-chars 8 inner-lines 1 max-chars 8 err_message label "Message" view-as editor size 130 by 4 with down size 160 by 50 AT COLUMN 1 ROW 7 frame b. The 3rd field displays 2 lines on row 1 then I think has scrolled off the rest of the rows. Attached is what I get. Help Please, Thanks.
