Hi All,
I'm really hoping someone can help me out here with this problem. I'm fairly new to both Progress and ODBC, so I could very well be missing something staring me something straight in the face. I'm trying to compile the DBD::ODBC module for Perl with the ODBC driver included in the 9.1E installation (the Merant driver). I believe I have all my environment variables set correctly, and I'm running Linux:
So, in the DBD::ODBC installation directory, I run Makefile.PL after a few edits that I actually extracted from a DataDirect document. It runs, with the following output, and all seems to be going well.
then, I run make, with warnings that don't look too bad to me...
then, I run 'make test', and get overloaded with errors. I'll display the entire output below, but it essentially goes like this:
So, I'm a bit confused. I'm wondering if I'm simply missing something simple here, or if anyone has run into a similar problem. Any help or information at all is very much appreciated!
Best,
-Adam
The full make test output follows:
DLC=/usr/local/dlc9.1e
TERM=xterm
SHELL=/bin/bash
HISTSIZE=1000
SSH_CLIENT=::ffff:10.0.1.2 34281 22
PROLIBPATH=:/usr/local/dlc9.1e/odbc/lib
WRKDIR=/usr/local/prowork
OLDPWD=/home/adrade/src
SSH_TTY=/dev/pts/13
USER=adrade
LD_LIBRARY_PATH=:/usr/local/dlc9.1e/odbc/lib
LS_COLORS=no=00:fi=00:di=00;34:ln=00;36:pi=40;33:so=00;35:bd=40;33;01:cd=40;33;01:or=01;05;37;41:mi=01;05;37;41:ex=00;32:*.cmd=00;32:*.exe=00;32:*.com=00;32:*.btm=00;32:*.bat=00;32:*.sh=00;32:*.csh=00;32:*.tar=00;31:*.tgz=00;31:*.arj=00;31:*.taz=00;31:*.lzh=00;31:*.zip=00;31:*.z=00;31:*.Z=00;31:*.gz=00;31:*.bz2=00;31:*.bz=00;31:*.tz=00;31:*.rpm=00;31:*.cpio=00;31:*.jpg=00;35:*.gif=00;35:*.bmp=00;35:*.xbm=00;35:*.xpm=00;35:*.png=00;35:*.tif=00;35:
MAIL=/var/spool/mail/adrade
PATH=/usr/local/dlc9.1e/bin:/usr/kerberos/bin:/usr/dlc/bin:/usr/local/bin:/bin:/usr/bin:/usr/X11R6/bin:/home/adrade/bin
INPUTRC=/etc/inputrc
PWD=/home/adrade/src/DBD-ODBC-1.13
LANG=en_US.UTF-8
PS1=proenv>
SSH_ASKPASS=/usr/libexec/openssh/gnome-ssh-askpass
DBI_DSN=dbi:ODBC:dbname
SHLVL=2
HOME=/home/adrade
ODBCINI=/usr/local/dlc9.1e/odbc/odbc.ini
LOGNAME=
ODBCHOME=/usr/local/dlc9.1e/odbc
SSH_CONNECTION=::ffff:10.0.1.2 34281 ::ffff:10.10.1.152 22
DLCBIN=/usr/dlc/bin
DBI_USER=
LESSOPEN=|/usr/bin/lesspipe.sh %s
G_BROKEN_FILENAMES=1
_=/bin/env
Useless use of private variable in void context at Makefile.PL line 435.
Configuring DBD::ODBC ...
>>> Remember to actually *READ* the README file!
And re-read it if you have any problems.
Using DBI 1.54 (for perl 5.008008 on i686-linux) installed in /usr/local/lib/perl5/site_perl/5.8.8/i686-linux/auto/DBI/
Using ODBC in /usr/local/dlc9.1e/odbc
Umm, this looks like a intersolve type of driver manager.
You seem to have the official header files.
Injecting selected odbc driver into cc command
Writing Makefile for DBD::ODBC
The DBD::ODBC tests will use these values for the database connection:
DBI_DSN=dbi:ODBC:dbname e.g. dbi:ODBC:demo
DBI_USER=user
DBI_PASS=
Warning: not all required environment variables are set.
>make
cp Changes blib/lib/DBD/ODBC/Changes.pm
cp ODBC.pm blib/lib/DBD/ODBC.pm
/usr/bin/perl -p -e "s/~DRIVER~/ODBC/g" /usr/local/lib/perl5/site_perl/5.8.8/i686-linux/auto/DBI/Driver.xst > ODBC.xsi
/usr/bin/perl /usr/local/lib/perl5/5.8.8/ExtUtils/xsubpp -typemap /usr/local/lib/perl5/5.8.8/ExtUtils/typemap ODBC.xs > ODBC.xsc && mv ODBC.xsc ODBC.c
Warning: duplicate function definition 'data_sources' detected in ODBC.xs, line 202
cc -c -I. -I/usr/local/lib/perl5/site_perl/5.8.8/i686-linux/auto/DBI -I/usr/local/dlc9.1e/odbc/include -fno-strict-aliasing -pipe -Wdeclaration-after-statement -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -I/usr/include/gdbm -O2 -DVERSION=\"1.13\" -DXS_VERSION=\"1.13\" -fpic "-I/usr/local/lib/perl5/5.8.8/i686-linux/CORE" ODBC.c
cc -c -I. -I/usr/local/lib/perl5/site_perl/5.8.8/i686-linux/auto/DBI -I/usr/local/dlc9.1e/odbc/include -fno-strict-aliasing -pipe -Wdeclaration-after-statement -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -I/usr/include/gdbm -O2 -DVERSION=\"1.13\" -DXS_VERSION=\"1.13\" -fpic "-I/usr/local/lib/perl5/5.8.8/i686-linux/CORE" dbdimp.c
Running Mkbootstrap for DBD::ODBC ()
chmod 644 ODBC.bs
rm -f blib/arch/auto/DBD/ODBC/ODBC.so
LD_RUN_PATH="/usr/local/dlc9.1e/odbc/lib" cc -shared -L/usr/local/lib ODBC.o dbdimp.o -o blib/arch/auto/DBD/ODBC/ODBC.so \
-L/usr/local/dlc9.1e/odbc/lib -R/usr/local/dlc9.1e/odbc/lib -lodbc \
cc: unrecognized option `-R/usr/local/dlc9.1e/odbc/lib'
chmod 755 blib/arch/auto/DBD/ODBC/ODBC.so
cp ODBC.bs blib/arch/auto/DBD/ODBC/ODBC.bs
chmod 644 blib/arch/auto/DBD/ODBC/ODBC.bs
Manifying blib/man3/DBD::ODBC.3
DBI connect('majdb','root',...) failed: Specified driver could not be loaded (SQL-IM003)(DBD: db_login/SQLConnect err=-1)
Best,
-Adam
>make test
PERL_DL_NONLAZY=1 /usr/bin/perl "-MExtUtils::Command::MM" "-e" "test_harness(0, 'blib/lib', 'blib/arch')" t/*.t
t/01base.........ok
t/02simple.......ok 1/36DBI connect('majdb','root',...) failed: Specified driver could not be loaded (SQL-IM003)(DBD: db_login/SQLConnect err=-1) at t/02simple.t line 21
Undefined subroutine &main::BAILOUT called at t/02simple.t line 23.
# Looks like you planned 36 tests but only ran 2.
# Looks like your test died just after 2.
t/02simple.......dubious
Test returned status 255 (wstat 65280, 0xff00)
DIED. FAILED tests 3-36
Failed 34/36 tests, 5.56% okay
t/03dbatt........ok 1/24DBI connect('majdb','root',...) failed: Specified driver could not be loaded (SQL-IM003)(DBD: db_login/SQLConnect err=-1) at t/03dbatt.t line 24
Undefined subroutine &main::BAILOUT called at t/03dbatt.t line 26.
# Looks like you planned 24 tests but only ran 2.
t/03dbatt........dubious
DIED. FAILED tests 3-24
Failed 22/24 tests, 8.33% okay
t/05meth.........ok 1/8DBI connect('majdb','root',...) failed: Specified driver could not be loaded (SQL-IM003)(DBD: db_login/SQLConnect err=-1) at t/05meth.t line 24
Undefined subroutine &main::BAILOUT called at t/05meth.t line 26.
# Looks like you planned 8 tests but only ran 1.
# Looks like your test died just after 1.
t/05meth.........dubious
DIED. FAILED tests 2-8
Failed 7/8 tests, 12.50% okay
t/07bind.........ok 1/11DBI connect('majdb','root',...) failed: Specified driver could not be loaded (SQL-IM003)(DBD: db_login/SQLConnect err=-1) at t/07bind.t line 22
Undefined subroutine &main::BAILOUT called at t/07bind.t line 24.
# Looks like you planned 11 tests but only ran 1.
t/07bind.........dubious
DIED. FAILED tests 2-11
Failed 10/11 tests, 9.09% okay
t/08bind2........ok 1/5DBI connect('majdb','root',...) failed: Specified driver could not be loaded (SQL-IM003)(DBD: db_login/SQLConnect err=-1) at t/08bind2.t line 26
Undefined subroutine &main::BAILOUT called at t/08bind2.t line 28.
# Looks like you planned 5 tests but only ran 2.
t/08bind2........dubious
DIED. FAILED tests 3-5
Failed 3/5 tests, 40.00% okay
t/09multi........ok 1/7DBI connect('majdb','root',...) failed: Specified driver could not be loaded (SQL-IM003)(DBD: db_login/SQLConnect err=-1) at t/09multi.t line 26
Undefined subroutine &main::BAILOUT called at t/09multi.t line 28.
# Looks like you planned 7 tests but only ran 3.
# Looks like your test died just after 3.
t/09multi........dubious
DIED. FAILED tests 4-7
Failed 4/7 tests, 42.86% okay
t/20SqlServer....ok 1/37DBI connect('majdb','root',...) failed: Specified driver could not be loaded (SQL-IM003)(DBD: db_login/SQLConnect err=-1) at t/20SqlServer.t line 47
Undefined subroutine &main::BAILOUT called at t/20SqlServer.t line 49.
# Looks like you planned 37 tests but only ran 2.
t/20SqlServer....dubious
DIED. FAILED tests 3-37
Failed 35/37 tests, 5.41% okay
t/30Oracle.......ok 1/4DBI connect('majdb','root',...) failed: Specified driver could not be loaded (SQL-IM003)(DBD: db_login/SQLConnect err=-1) at t/30Oracle.t line 26
Undefined subroutine &main::BAILOUT called at t/30Oracle.t line 28.
# Looks like you planned 4 tests but only ran 2.
t/30Oracle.......dubious
DIED. FAILED tests 3-4
Failed 2/4 tests, 50.00% okay
Failed Test Stat Wstat Total Fail Failed List of Failed
t/02simple.t 255 65280 36 68 188.89% 3-36
t/03dbatt.t 255 65280 24 44 183.33% 3-24
t/05meth.t 255 65280 8 14 175.00% 2-8
t/07bind.t 255 65280 11 20 181.82% 2-11
t/08bind2.t 255 65280 5 6 120.00% 3-5
t/09multi.t 255 65280 7 8 114.29% 4-7
t/20SqlServer.t 255 65280 37 70 189.19% 3-37
t/30Oracle.t 255 65280 4 4 100.00% 3-4
Failed 8/9 test scripts, 11.11% okay. 117/137 subtests failed, 14.60% okay.
make: *** [test_dynamic] Error 255
