I am a newbie both to this discussion group and to Progress.
I am NOT sure if this is the correct place for the but here goes.
I installed ProVision Plus 9.0B with a complete Installation on Windows NT machine.
Then after it is complete and the machine was rebooted, I go into Adminstrator Tools' ODBC Data Source. Under the User DSN tab, I click add. I select the Progress. Then I fill in the Host Name with the IP Address of the machine, and Port #31, and gave the DB Name, Data Source Name, and User ID. I then selected apply. Then I hit Test Connect. It brings up a screen marked "Logon to Progress SQL92 Driver". I hit OK after entering the password. I then receive the following:
Warning
[MERANT][ODBC PROGRESS driver][PROGRESS]Error in Network Daemon
1) What did I do wrong/what did I NOT do?
2) How do I fix this problem?
Any help would be appreciated.
Thanks.
Warning
Thanks.
